MRV
Max resolution for stereo?
Thu Jan 16, 2020 1:34 pm
Hello.
We are using a Compute Module 3+ attached to a custom carrier board with two cameras - this allows for the acquisition of stereo imagery using Raspivid. Currently we are restricted to 1920 x 1080 encoding. Is there a way, either on PI3+ or PI4, to increase this size to at least 2048 x 1024?
Thanks.
6by9
Re: Max resolution for stereo?
Thu Jan 16, 2020 3:07 pm
No. The codec hardware has an internal line buffer that is of a fixed size.
I had expected it to be 2048 pixels wide to accomodate 2,048×1,[email protected] that is specified as part of level 4.0, but something goes wrong in the config of the last macroblock column, and (memory says) 2032 is the highest width that works.
MRV
Thu Jan 16, 2020 3:24 pm
Is 2032 x 1016 possible?
6by9
Thu Jan 16, 2020 3:45 pm
It should be for simple encode, but won't be for stereoscopic as it doesn't meet the requirement for the width of each image being a multiple of 128.
MRV
Thu Jan 16, 2020 4:51 pm
Is there an active bug ticket regarding this? (config of the macroblock column)
Would like to see the PI actually being able to get what the level 4 spec says it should. 2048x1024 would be excellent.
quote=6by9 post_id=1596450 time=1579189555 user_id=92334]
[/quote]
6by9
Thu Jan 16, 2020 5:09 pm
It's so far down the priorities list I don't think it is being actively tracked - sorry.
You could check for or create an issue at https://github.com/raspberrypi/firmware/issues, but it's not going to boost the priority.
We no longer have developers who know the intimate detail of the codec code, and it may well be the hardware itself that isn't capable of doing it. From extracting the motion vectors we know that we get an extra column of vectors, so it may be the setup there that either requires it or is wrong, but you're probably talking a couple of man days of time to determine if that is the case, and then you need to understand whether that is necessity or accident.
MRV
Thu Jan 16, 2020 5:17 pm
And the PI3+ and PI 4 both have this issue (limitation)?
6by9
Thu Jan 16, 2020 5:50 pm
All versions of the Pi share the same codec block.
MRV
Sat Jan 18, 2020 6:05 pm
Is there a reason that the RAM, CPU frequency and kernels have improved yet there has been no improvement regarding the video encoder (GPU)?
6by9
Sat Jan 18, 2020 10:16 pm
Mainly expertise and ownership.
Cranking up ARM cores is relatively simple as you buy in the relevant IP from ARM. Interfacing to alternate RAM providers depends on finding a suitable package and wiring it up.
The H264/MPEG4/H263/MPEG2/VC-1 codec block is a Broadcom IP block, so support really needs to come from them. They no longer sell any other products using this block, so they have no interest in investing effort into updating it. Most of their multimedia devices are for set top boxes, so decode is their requirement, not encode.
AFAIK ARM don't sell a video encode IP block, so you can't easily buy one off the shelf and plug it to your chip. (Licencing and avoiding cross-contamination would get entertaining anyway with Broadcom making the chip and designing their own codec blocks)
CPU performance and software is catching up to the extent that the need for hardware acceleration is significantly reduced. There are parts that can be usefully hardware accelerated (eg CABAC, and motion searching), but the rest can be run on the CPU. Someone observed recently that video decode through the hardware blocks achieved around 60fps, when software decode could hit about 110fps.
We have invested in video decode for HEVC on Pi4. The block does have some other options, but I don't recall the details.
The ISP isn't rated significantly higher than the video_encode block anyway - somewhere around 150MPix/s in reality for Bayer images, so 75fps at 1080p. ARM definitely don't do a decent ISP, therefore without a new design from scratch for that you'd be struggling to create the content to encode.
It's all an area that is being looked at and the use cases considered.
Return to “Advanced users”
