dsyleixa123
suddenly no LXterminal available any more
Thu Jan 16, 2020 1:09 pm
suddenly no LXterminal available any more:
bash scripts can not be executed,
and from file manager -> tools -> open directory in terminal => =>
"child process LXterminal cannot be executed (file or path not found)"
how can I fix that?
Botspot
Re: suddenly no LXterminal available any more
Thu Jan 16, 2020 2:23 pm
There's an easy way to do it. Just reflash your SD card.
Otherwise, you can try to fix the problem. Menu --> Preferences --> Add / Remove Software. Try reinstalling lxterminal, and while you're at it, install an alternative terminal like guake or xterm.
My doctor told me my brain is as useful as a Raspberry Pi. Is that a compliment?
dsyleixa123
Thu Jan 16, 2020 3:01 pm
it came to that issue when I set the screen to large screen defaults (appearance settings).
reinstalling lxterminal replies: already the newest version
it can be started from the systray, but not from file manager or from bash scripts.
trying to open the terminal from a file manager path makes this window appear:
https://github.com/dsyleixa/RaspberryPi ... nshot.jpeg
what do I have to fill in?
or which way to re-configure somewhere else?
Botspot
Thu Jan 16, 2020 3:17 pm
The proper way to do it is to put "x-terminal-emulator %s" in the Terminal Emulator line:
dsyleixa123
Thu Jan 16, 2020 3:19 pm
edit, cross-over posting -
solved :
appearently just
lxterminal // (lowercase)
in the first line
(and NOT LXterminal)
but for new issues I'll then try your proposal, too!
thanks a lot!
