rpiMike
Re: Minecraft Pi edition (Stretch): how to create an infinite plain of sand?
Thu Jan 16, 2020 1:59 pm
dsyleixa123 wrote:
Thu Jan 16, 2020 1:57 pm
the lowest level (z=-64)
why z?
isn't it y?
Sorry, yes, you are right its y=-64
dsyleixa123
Thu Jan 16, 2020 2:02 pm
so for the entire world:
world.setBlocks(x1,y1,z1,  x2,y2,z2,  block_type)
world.setBlocks(-254,-20,-254,  254,0,254,  block.SANDSTONE.id)   # layer thickness of 20 blocks
rpiMike
Thu Jan 16, 2020 3:26 pm
It looks like worlds are not centred !
This works out the edges, then fills the world.
import mcpi.minecraft as minecraft
import mcpi.block as block
import time
def findEdge(xz,inc):
    v=0
    id=0
    while True:
        if xz == 'x':
            id = mc.getBlock(v,0,0)
        else:
            id = mc.getBlock(0,0,v)
        #print(x,id)
        if id==95 or (inc == -1 and v<-256) or (inc == 1 and v>256):
            break
        v+=inc
    if inc == 1:
        v-=1
    else:
        v+=1
    return v
print('begin')
mc = minecraft.Minecraft.create()
mc.postToChat('starting')
time.sleep(0.5)
minx = findEdge('x',-1)
minz = findEdge('z',-1)
maxx = findEdge('x',1)
maxz = findEdge('z',1)
print('min x',minx)
print('min z',minz)
print('max x',maxx)
print('max z',maxz)
print(maxx-minx+1,maxz-minz+1)
# fill sky
mc.setBlocks(minx,0,minz,maxx,64,maxz,0)
# fill ground
mc.setBlocks(minx,-20,minz,maxx,0,maxz,block.SANDSTONE.id)
mc.postToChat('finished')
print('end')
dsyleixa123
Thu Jan 16, 2020 3:33 pm
I actually do not want to find edges, I just wanted an entire sandstone (id=24) plain like e.g.,
mc.setBlocks(-128,-20,-128,  128,0,128,  24)
or even
mc.setBlocks(-254,-20,-254,  254,0,254,  24)
for all and everything?
rpiMike
Thu Jan 16, 2020 3:37 pm
You need to know where the edges are or you may not fill your world. My code will fill the entire world.
If 254 works for you great, my Pi3 hung using 256.
dsyleixa123
Thu Jan 16, 2020 3:47 pm
aah, ok, I understand and try out!
dsyleixa123
Thu Jan 16, 2020 4:02 pm
indeed, it's extremely unsymmetrical:
begin
min x -13
min z -178
max x 242
max z 77
256 256
end
I'm afraid, for my purposes I needed a symmetrical map round (0,0) or a (0,0) origin map,
so either x=-100...+100, z=-100...+100
or perhaps x=0...200, z=0...200
but what mc provides is too odd, and probably mc is also far too slow for my purposes, too, as far I had tested... :(
but thank you very very much for your efforts so far, you really helped me a lot to learn and to understand about mc and Python! 8)
(edited, code see below)
rpiMike
Thu Jan 16, 2020 4:53 pm
What are you actually trying to do? Why can't you just have an offset x & z to relocate the centre?
dsyleixa123
Thu Jan 16, 2020 5:48 pm
update
the simplified indices now appearantly are correct, just the code is still somehow (unexpectedly) bugged
dsyleixa123
Mon Jan 20, 2020 12:50 pm
update:
it's for my mc Python implementation of Conway's Game Of Life -
and now it works! (silly bugs before!)
Nonetheless, it's incredible slow on my Pi 2, even on a 20x20 field .... and 200x200 (wishfully even up to 1000x1000) once had been intended!
#!/usr/bin/python
import RPi.GPIO as GPIO
import time
# ver 004
GPIO.setmode(GPIO.BCM)
p1 = 8
GPIO.setup(p1, GPIO.IN, GPIO.PUD_DOWN)
bl_1 = block.GRASS.id
bl_0 = block.SANDSTONE.id
msize = 20   # size of game map
Tmp = [[0]*(msize+2) for _ in range(msize+2)] # plus 2 for border frame
def putField_Glider(x,y,z):
    mc.setBlock(x+0, y, z+0, bl_0)
    mc.setBlock(x+1, y, z+0, bl_0)
    mc.setBlock(x+2, y, z+0, bl_1)
    mc.setBlock(x+0, y, z+1, bl_1)
    mc.setBlock(x+1, y, z+1, bl_0)
    mc.setBlock(x+2, y, z+1, bl_1)
    mc.setBlock(x+0, y, z+2, bl_0)
    mc.setBlock(x+1, y, z+2, bl_1)
    mc.setBlock(x+2, y, z+2, bl_1)
def clearField_n(x,y,z, n):
  for i in range(0,n+1):
    for j in range(0,n+1):
      mc.setBlock(x+i, y, z+j, bl_0)
def clearField_radius(x,y,z, r):
  for i in range(-r,r+1):
    for j in range(-r,r+1):
def countNeighbours(x,y,z):
  count = 0
  for i in range(-1,2):
       for j in range (-1,2):
            if(( mc.getBlock(x+i,y,z+j) != bl_0) and (i!=0 or j!=0)):
                 count=count+1
  return count
def calcGeneration():
  aliveNeighbours = 0
  y = 0
  for x in range(1,msize):
    #debug
    print("   line ", x, "/",msize-1)
    for z in range(1,msize):
      aliveNeighbours=countNeighbours(x,y,z)
      #debug
      #print(x,z, " alvNbs=",aliveNeighbours)
      if aliveNeighbours < 2:  # cell dies
        Tmp[x][z] = bl_0
      if aliveNeighbours>=2 and aliveNeighbours<=3:  # cell lives
        Tmp[x][z] = mc.getBlock(x,y,z)
      if aliveNeighbours==3 :  # dead cell resurrects
        if mc.getBlock(x,y,z) == bl_0:
          Tmp[x][z] = bl_1
      if aliveNeighbours > 3:  # cell dies
        Tmp[x][z] = bl_0
  y=0
  for x in range(0,msize+1):                     # not tested yet
    for z in range(0,msize+1):
      if x==0 or z==0 or x==msize or z==msize:
        Tmp[x][z] = bl_0
      mc.setBlock(x,y,z, Tmp[x][z])
try:
  clearField_n(1,0,1, msize)
  mc.setBlock(1,1,1, block.TORCH.id)
  putField_Glider(1,0,1)
  # test,
  for g in range (1,20):
    print()
    print("Generation= ", g)
    calcGeneration();
except KeyboardInterrupt:
  GPIO.cleanup()
rpiMike
Mon Jan 20, 2020 3:25 pm
Couldn't help myself hack this about, basically do all of your calculations on 2 arrays, then just write each calculation output to Minecraft :
import time
# ver 004
def printTmp():
    print('Tmp')
    for row in Tmp:
        for val in row:
            if val == 24:
                print('-',end='')
            elif val == 2:
                print('*',end='')
            #print(f'{val:02} ',end='')
        print('')
def printTmp2():
    print('Tmp2')
    for row in Tmp2:
        for val in row:
            if val == 24:
                print('-',end='')
            elif val == 2:
                print('*',end='')
        print('')
    #global Tmp
    Tmp[x+0][z+0] = bl_0
    Tmp[x+1][z+0] = bl_0
    Tmp[x+2][z+0] = bl_1
    Tmp[x+0][z+1] = bl_1
    Tmp[x+1][z+1] = bl_0
    Tmp[x+2][z+1] = bl_1
    Tmp[x+0][z+2] = bl_0
    Tmp[x+1][z+2] = bl_1
    Tmp[x+2][z+2] = bl_1
#     mc.setBlock(x+0, y, z+0, bl_0)
#     mc.setBlock(x+1, y, z+0, bl_0)
#     mc.setBlock(x+2, y, z+0, bl_1)
#     mc.setBlock(x+0, y, z+1, bl_1)
#     mc.setBlock(x+1, y, z+1, bl_0)
#     mc.setBlock(x+2, y, z+1, bl_1)
#     mc.setBlock(x+0, y, z+2, bl_0)
#     mc.setBlock(x+1, y, z+2, bl_1)
#     mc.setBlock(x+2, y, z+2, bl_1)
  print('clearField_n()')
  #for i in range(0,n+1):
  #  for j in range(0,n+1):
  #    mc.setBlock(x+i, y, z+j, bl_0)
  for i in range(0,n):
    for j in range(0,n):
      Tmp2[x+i][z+j] = bl_0
  count = 0
            #print('i,j',i,j)
            #if(((i!=0 or j!=0) and mc.getBlock(x+i,y,z+j) != bl_0)):
            #     count+=1
            if(( Tmp[x+i][z+j] != bl_0) and (i!=0 or j!=0)):
                 count=count+1
  return count
  aliveNeighbours = 0
  y = 0
    #debug
      #debug
        Tmp2[x][z] = bl_0
        #Tmp2[x][z] = mc.getBlock(x,y,z)
        Tmp2[x][z] = Tmp[x][z]
        #if mc.getBlock(x,y,z) == bl_0:
        if Tmp[x][z] == bl_0:
          Tmp2[x][z] = bl_1
        Tmp2[x][z] = bl_0
  y=0
        Tmp2[x][z] = bl_0
      mc.setBlock(x,y,z, Tmp2[x][z])
      Tmp[x][z] = Tmp2[x][z]
try:
  p1 = 8
  Tmp = [[bl_0]*(msize+2) for _ in range(msize+2)] # plus 2 for border frame
  Tmp2 = [[bl_0]*(msize+2) for _ in range(msize+2)] # plus 2 for border frame
  #printTmp()
  # test,
    print()
    calcGeneration()
    #printTmp2()
  GPIO.cleanup()
dsyleixa123
Mon Jan 20, 2020 4:58 pm
yes, that was my approach before 8-) :
actually I already tried that, but it was not noteably faster, regrettably.
OTOH it then was lacking of a user-interface (putting optionally new blocks manually to the fields using the mc player)
dsyleixa123
Mon Jan 20, 2020 5:03 pm
perhaps multithreading could speed it up, calculating the neighbours from either field corner to the center point, and then writing all tmp values to the fields, also multi-threaded. But I actually doubt that Python and mc would support that, tbh... :roll:
rpiMike
Mon Jan 20, 2020 5:06 pm
It seemed faster on my Pi4 with this approach.
dsyleixa123
Mon Jan 20, 2020 5:10 pm
yes, ok, well, perhaps a little, but one needed to copy all field blocks to tmp1 in each generation cycle, to read intermediate user actions, and at the very latest it's even slower than computing the "real" mc field with 1 single tmp map then, unfortunately.
Anyway, it was a nice challenge ;)
Return to “Gaming”
