Good day, I would just like to know if a raspberry pi can do the following task and if so what other hardware do I need?
It must be able to receive 6 pulses, and then drive 2 12v motors. 3 pulses for the big motor and 3 for the small motor, there should also be a sensor and each pulse has a predefined distance to travel. The last thing I want to add is a start button and stop button, this should not effect the distance traveled but just put it on pause until it is started again. The motors will also only start when the start button is pressed. Any help and information on this will be much appreciated. Thank you all and have a great day.
