I am a quite well experienced Raspi Fan - having started years ago - right from the early beginning of the Raspi - story.
But in the last days I have experienced a very strange problem - never seen before:
I am using an 8GB INTENSO SD-card - a supplier brand without any problems for me within years - in a Raspberry Pi 2 Model B Rev 1.1 with Raspbian GNU/Linux 8 (jessie)
Since some days I have realized that the boot sequence is taking minutes, instead estimated 60 seconds max. or less. I had assumed the root cause by special network problems when getting an IP-address via DHCP and in parallel spanning a seperate AdHoc wifi network - working with some bridge functionality.
But yesterday I have realized - the problem is very different:
Doing an SD-card image backup via win32DiskManager the Read-Process for 6GB (without unallocated blocks) took 60 minutes fairly !!!
Immediately I have assumed that the SD-card Hardware is damaged - also explaining the long boot sequence - and I have deployed a brand new 8GB intenso SD-card.
The RESTORE cycle to this with the before Backup image was done in a few minutes - so I was pretty sure, having detected the root cause for the slow boot period. Booting with the brand new SD-card confirmed me - done in 45 seconds for fully powering up - great. Heh - problem solved !
Now I did a Double Check:
I have restored the Backup also to the "broken" SD-card - you won't believe it - done in some minutes, same short Restore time as before with the new one.
Following another Check - I have now made a win32DiskManager Backup again from the "broken" SD-card - done in some few minutes (less than 5) ...! No problems any more!
I could have explained this "healing" process in a Backup & Restore cycle by some block reorganisation similar to in a fragmented file system or dammaged partition.
But we alle know, that win32DiskManager is just doing a stupid 1:1 Block copy - no intelligent structure reorganisation process behind.
What's going on here? Can somebody explain me, please?
Any ideas are appreciated, thanks for your help.
BR from WiFi
