n3tm4n
RPi 3b+ or RPi 4 WPA2e (WPA2 Enterprise)
Thu Jan 09, 2020 1:58 pm
I've recently been asked to provide a quick How-To by a colleague trying to get WPA2 enterprise configured on a RPI4. I thought I would also post it here in case if it of any use to the wider community.
This has been tested on the following releases:
* Raspbian Buster with desktop and recommended software(September 2019)
* Raspbian Buster with desktop (September 2019)
* Raspbian Buster Lite (September 2019)
Tested on the following versions of Raspberry Pi
* Raspberry Pi 3b+
* Raspberry Pi 4
From a fresh SD image (no updates required etc at the moment)
Create a new file
nano /etc/network/interfaces.d/wpa2enterprise
with the following.
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
  pre-up wpa_supplicant -B -Dwext -i wlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
  post-down killall -q wpa_supplicant
Before we create the referenced file, we need to obtain a hashed version of the password to be used for WiFi authentication. The following command will create the hash:
echo -n 'your_password_in_plaintext' | iconv -t utf16le | openssl md4 > hash.txt
The resulting hash.txt file will look similar to below:
(stdin)= 0958d73cdb5ag8956cd29c0aeaa101a506
We need the string without leading or trailing white spaces, in this example it will be
We should now have the information for the following 3 placeholders.
%%%NETWORK_SSID%%%
%%%ACCOUNT_LOGIN_ID%%%
%%%PASSWORD_HASH_GENERATED_ABOVE%%%
Next create / edit the new referenced
nano /etc/wpa_supplicant/wpa_supplicant.conf
as shown below replacing the strings as appropriate.
update_config=1
country=GB
network={
	ssid="%%%NETWORK_SSID%%%"
	proto=RSN
	key_mgmt=WPA-EAP
	auth_alg=OPEN
	eap=PEAP
	identity="%%%ACCOUNT_LOGIN_ID%%%"
	password=hash:%%%PASSWORD_HASH_GENERATED_ABOVE%%%
	phase1="peaplabel=0"
	phase2="auth=MSCHAPV2"
	priority=1
Once you have created the files specified above, with the appropriate details updated. Reboot the Raspberry Pi and it should auto connect to the requested SSID assuming user id and password are correct.
HTH.
N3TM4N
