pidood1234
pigpio software PWM jitters when run together with raspivid
Mon Jan 06, 2020 5:40 pm
I’m trying to run software PWM using the pigpio library to generate software PWM. Individually without running raspivid , the spftware works and I can spin a brushless motor. However when I turn on raspivid, the software PWM jitters — specifically, the software PWM is actually output at about 10% which is enough to spin the motor even though I did not output anything from my software. Any clues as to whats causing this?
pidood1234
Re: pigpio software PWM jitters when run together with raspivid
Mon Jan 06, 2020 5:42 pm
Specifically, raspivid is run in a separate ssh session (headless) , and my pigpio software is run on another ssh session also. The hardware used is raspi zero w. OS used is the latest raspbian.
joan
Mon Jan 06, 2020 5:55 pm
Presumably there is a conflict. Have you tried starting pigpio with the PWM clock rather than the PCM clock (or vice versa). See the -t option at http://abyz.me.uk/rpi/pigpio/pigpiod.html
If it's not that then perhaps there is a clash with DMA channel usage. I know nothing about raspivid and don't know if it uses DMA. If it does again see -d -e http://abyz.me.uk/rpi/pigpio/pigpiod.html to select a different DMA channel.
pidood1234
Thu Jan 16, 2020 5:11 pm
I tried updating the clock source between PWM and PCM, but the issue still persists.
Also tried changing up the different channels for DMA primary and secondary channels, also have the same issue.
One condition that worked sometimes is that raspivid does not trigger the software PWMs, but what ends up happening is when I try to exit out of my code and call gpioTerminate(), the program never returns, i.e. it's stuck and does not even respond to a Ctrl+C. When I rerun gpioInitialize(), it turns up with the error
cannot lock /var/run/pigpio.pid
, so I have to power cycle the pi, and then the raspivid will interfere with PWM again. Any idea what's causing this loop above to hang?
joan
Thu Jan 16, 2020 6:03 pm
I don't know what is happening.
You can delete the pid file so you don't need to reboot.
sudo rm /var/run/pigpio.pid
6by9
Fri Jan 17, 2020 2:06 pm
Which GPIOs are you using?
How busy is the CPU when running both apps?
