japaton
RPi Zero digitalRead unreliable?
Mon Jan 06, 2020 5:03 pm
I have created a simple reminder for my aging Mother-In-Law as a first project. (She has to call the front desk of the retirement community every morning around 8:00 to tell them she's okay.) The program activates a relay to turn on a light reminding her to call, then turns it off when a momentary contact button is pressed or after 120 minutes has lapsed. The program is fired by a cron every morning at 8:00am. The whole thing runs headless in a box with the button on top. It usually works perfectly, but sometimes the relay switches off after 20 or 30 minutes without the button being pressed. I have attached a diagram of the circuit, and the code is below.
Can someone please help me discover why the digitalRead appears to test high sometimes without the button being pressed? Maybe some transient voltage appearing? Do I need to ground it somehow? Or do I need a more reliable way of testing the button?
Thanks.
#include <wiringPi.h>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#define RelayPin 1   // raspberry pin 18
#define ButtonPin 0  // raspberry pin 17
int main(void)
    if(wiringPiSetup() == -1) return 1;	// exit immediately if setup fails
    int min = 120;			// number of minutes until time lapses
    time_t starting = time(NULL);	// time stamp (seconds) when program starts
    time_t ending = starting + min*60;	// time when program will end if button not pressed
    pinMode (ButtonPin, OUTPUT);   	// set button to output temporarily
    digitalWrite(ButtonPin, LOW);	// make sure button pin is low
    pinMode (ButtonPin, INPUT);   	// reset button to input
    pinMode (RelayPin, OUTPUT);   	// set relay pin to output
    digitalWrite (RelayPin, HIGH); 	// close relay (turn lights on) before loop
    while (digitalRead(ButtonPin) == LOW && time(NULL) < ending)
	delay (1);    // loop on 1ms until button pressed (pin 17 goes high) or time lapses
    digitalWrite (RelayPin, LOW); 	// open the relay (turn lights off) before exit
    return 0;
Screen Shot 2020-01-06 at 11.53.56 AM.png (62.07 KiB) Viewed 247 times
mahjongg
Re: RPi Zero digitalRead unreliable?
Mon Jan 06, 2020 5:09 pm
A Velleman VMA406 relay module is not compatible with the 3V3 output signals of a PI, its designed for an Arduino.
You need a transistor inverter to drive it.
+Vs = +5V, the transistor can be any NPN small signal transistor, such as a BC547, or a 2N2222
trejan
Mon Jan 06, 2020 5:18 pm
This isn't how you set a pulldown. Remove the output and digitalwrite calls. Set to input and use pullUpDnControl(ButtonPin, PUD_DOWN)
japaton
Mon Jan 06, 2020 5:22 pm
Thanks for the answer. So, I guess that although the 3v3 always trips the relay, it doesn't hold reliably. I appreciate the help.
PeterO
Mon Jan 06, 2020 6:21 pm
No, it looks like the issue is with how you are reading the button, not how you are driving the relay.
With no pull down configured it's quite possible that the pin may pick up noise on the wire to the button that may make it read as a "1".
PeterO
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
int main(void)
    pullUpDnControl(ButtonPin, PUD_DOWN);
    return 0;
hippy
Mon Jan 06, 2020 7:05 pm
Looking at the VMA405 board it seems to have the relay switching transiistor (Q1) and other components on-board, so seems almost certainly a missing internal pull-down issue.
japaton
Mon Jan 06, 2020 7:12 pm
Thanks for the answers. I will remove the logic to set the pin output/low, and add the pull-down.
