elfresno
how to install openpyxl in python3
Wed Jan 01, 2020 6:57 am
Hi, I'm trying to install openpyxl in Python 3, but I can't. in python 2 there is no problem but with 3 it doesn't let me.
sudo pip3 install openpyxl
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-v2ejztbq/openpyxl
Storing debug log for failure in /root/.pip/pip.log
sudo apt-get install python3-openpyxl
Reading package lists... Done
Building dependency tree... 50%
E: Unable to locate package python3-openpyxl
DirkS
Re: how to install openpyxl in python3
Wed Jan 01, 2020 12:35 pm
Which OS + version does your Pi run on?
python3-openpyxl seems to be available on Debian/Raspbian Stretch and later (not on Jessie)
And did you do an update before trying to install the package?
The problem with the pip command could be that you run a version of pip / setuptools that's too old.
That should be evident from the log file.
Return to “Python”
