boelle
ras pi 4 nas and replication over internet
Tue Dec 31, 2019 1:14 pm
I have an idea and it might not be so well thought out
but basicly i want to build a nas with raid 6, no problem finding guides etc for that
but i also want to have a remote copy of that (either at parents or friend etc)
it would be nice if both ends could write to the nas but not look in to each other files
so if i had the remote nas at my friend he should be able to write to it from windows and then his data would be replicated back to my nas and the other way round
i have looked at glusterFS but the guides for geo replications are not that good, and i have doubts if that is what i want/need
any ideas?
PS i know its overkill with raid6 and remote backup, but i like the "belt and suspender" method
PPS and of course the internet link will impact on how fast things can be replicated, but i would like it to be as fast as it can
epoch1970
Re: ras pi 4 nas and replication over internet
Tue Dec 31, 2019 2:19 pm
Perhaps syncthing could be of use?
boelle
Tue Dec 31, 2019 2:35 pm
will have a look at it ones newyear party stuff is over
i assume that it can be run on a pi too (screenshots where from mac)
epoch1970
Tue Dec 31, 2019 2:54 pm
Yes. I’ve seen it work fine on Pi3. Not the fastest, but robust and tenacious.
Mind that its main purpose is mirroring. Delete something on one side, it gets soon deleted everywhere.
boelle
Sat Feb 08, 2020 12:31 pm
i wanted to try ask this on the owncloud forum but some cert issue prevented me from accessing the site
anway, me and my uk based has been thinking about using own cloud
but will either of us be able to access the others data? one pi will of course run own cloud and the other pi will just sync the first ones data
but we dont want to be able to view each others data, not even if we both have access to both pi
own cloud was just the best we could think off to get encryption
castletonroad
Sat Feb 08, 2020 10:56 pm
I use 'rsync' to back up my Nextcloud instance on one raspberrypi in my house, to a second raspberry pi. There is no reason why this cannot be done from one IP to another.
You would need to ensure a fixed IP at one end: either you 'push' from your server to the back-up (which has the fixed IP), or you pull to the back-up from the server (which has the fixed IP).
Raspberry Pi 4 Model B | Raspberry Pi 3 Model B | Raspberry Pi 2 Model B
boelle
Sun Feb 09, 2020 12:41 am
boelle
not a problem, fixed ip at both ends
