beatsbybk
Wifi card : HARD
Sun Dec 29, 2019 10:03 pm
Hi there,
i recently purchased an archer t2u nano wifi card from tp link and it will not work, i have tried different drivers however i am unable to set any of them up.
The card is being detected by the rpi through lsusb but is not showing up as a wireless interfacing option.
Any idea on what to do?
LTolledo
Re: Wifi card : HARD
Mon Dec 30, 2019 12:58 am
in the absence of pertinent details about your setup.....
let me guess...
Some people be like:
MrEngman
Mon Dec 30, 2019 2:04 am
With your wifi dongle connected to the Pi post the output of commands
lsusb
uname -a
cat /etc/os-release
MrEngman
beatsbybk
Mon Dec 30, 2019 10:50 am
results:
lsusb
Bus 001 Device 007: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 008: ID 2357:011e TP-Link
Bus 001 Device 006: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 010: ID 1188:03f5 Bloomberg L.P.
Bus 001 Device 009: ID 1188:03ef Bloomberg L.P.
Bus 001 Device 005: ID 1188:03f1 Bloomberg L.P.
Bus 001 Device 004: ID 0556:0002 Asahi Kasei Microsystems Co., Ltd
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
I believe that it is bus 001 device 008
uname -a
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
thanks
epoch1970
Mon Dec 30, 2019 11:15 am
Hardware apparently requires an out of tree driver.
https://askubuntu.com/questions/1149117 ... untu-18-04
Not every piece of hardware is made to run with Linux. Check compatibility with Linux before you buy.
MrEngman
Mon Dec 30, 2019 11:53 am
results:
lsusb
uname -a
cat /etc/os-release
VERSION_ID="10"
ID=raspbian
ID_LIKE=debian
thanks
I have drivers I compile which support that wifi at http://downloads.fars-robotics.net/wifi-drivers/. You can download and install the necessary driver from a terminal window using commands
wget http://downloads.fars-robotics.net/wifi-drivers/8812au-drivers/8812au-4.19.75-v7-1270.tar.gz
tar xzf 8812au-4.19.75-v7-1270.tar.gz
./install.sh
If you update the kernel version you use you will need to install an updated driver version matching the new kernel version.
I also have a script that will automatically determine the driver you need for the wifi you use and the kernel version you are running so making it rather easier to reinstall the driver if you update the kernel version, no need for you to figure out the new driver version you need. You can install the script using commands
sudo wget http://downloads.fars-robotics.net/wifi-drivers/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
Command sudo install-wifi -h will show details on how to use the script. In its simplest form the command sudo install-wifi will determine the wifi you are using, determine the kernel version you have and automatically download and install the necessary driver.
MrEngman
beatsbybk
Mon Dec 30, 2019 12:26 pm
Great that works!!
thanks so much
:D :D
Return to “Advanced users”
