What is your favourite alternative modes you use for amateur radio or shortwave listening?
Echolink
18%
7
IRLP
8%
3
SSTV
5%
2
Digital TV
No votes
0
PSK31
33%
13
RTTY
18%
7
DRM
8%
3
AM (Shortwave)
10%
4
Total votes: 39
Frank_ZL1FMA
Uses in Amateur Radio
Tue Dec 18, 2012 3:29 am
It appears some members of the amateur radio are already excited. The potential for the Pi could only be limited by ones imagination. There are as many of you are aware many of the amateur radio programs are primarily designed for windows. Echolink, SlowScanTV(MSSTV), DigitalTV(Easypal),PSK31(MMVari). All however need a good soundcard, with mike input, linein, lineout, speakers out. It certainly would be interesting to see what could be developed/built on the scale started by the Raspberry Pi experimentation. Obviously the soundcard and software is the biggest hurdle for their use with the Raspberry Pi. Monitor and keyboard (mouse ?) input and output has been solved though I note VGA output does not feature on any model seen. Challenge as always would be initially the cost but I am sure their will be some experimenting amateurs out there, who have a better brain and steadier hands for construction than I and have more time available. My other use for the Raspberry would be suitable software and an USB plug in mini receiver for the new digital shortwave broadcasting DRM. To date such radios or software seem very expensive which again is one of those major challenges we all face in the development stages of any project. Just a few of my thoughts for the future. Be interested to read the feedback generated. Cheers and thankyou. 73.
Danbert
Re: Uses in Amateur Radio
Tue Dec 18, 2012 10:22 am
I'm planning to use mine for digital voice using Codec2 on V/UHF - the basic outline of my plan is here.
The soundcard problem is fairly easily solved with a pair of £5 USB soundcards (unless you are planning to do SDR in which case you might need one high quality card.) There's also a lot of software for the modes you mentioned - fldigi is my favourite for digimodes.
Dan (MD1CLV)
scruss
Tue Dec 18, 2012 1:52 pm
I'll have to revisit running fldigi on the Raspberry Pi, because it should work. Early attempts were stymied by firmware problems, now fixed. Considering I run my main radio rig from a $4 USB sound card (into a vastly overpriced RIGblaster Pro), I know that a cheap USB audio interface will be fine.
73 de VA3PID
Krella Krentoshi
Thu Jul 02, 2015 2:11 am
Has anyone tried taking a cheap ham radio (LIke a Baofeung), taking it apart and somehow directly connecting it to a Raspberry Pi to run digital Amateur Radio communications?
ame
Thu Jul 02, 2015 2:25 am
Krella Krentoshi wrote:Has anyone tried taking a cheap ham radio (LIke a Baofeung), taking it apart and somehow directly connecting it to a Raspberry Pi to run digital Amateur Radio communications?
If you ever wonder "Has anyone tried...?", probably the answer is yes, and probably they blogged about it, so Google will help you find it.
For example:
http://www.crompton.com/hamradio/irlp/a ... P7586.html
You can also buy a DRA818V module, which is essentially the guts of an HT.
http://w0anm.com/blog/?p=541
jwl
Mon Apr 17, 2017 4:25 pm
It shouldn't be necessary to take the radio apart in most cases. Just use the microphone / speaker connector on the side.
Here is some open source software that can be used on the Raspberry Pi for Packet Radio / APRS. You will need to add a cheap USB Audio adapter to get audio in and out of the RPi. A GPIO line can be used to activate the transmitter.
https://github.com/wb2osz/direwolf/blob ... /README.md
mahjongg
Mon Apr 17, 2017 5:51 pm
VGA output is easy and cheaply to add using Gerts VGA666 adapter, which uses only resistors and a VGA connector. viewtopic.php?p=657497#p657497
Or you could use a €10 passive HDMI to VGA adapter.
jamesmonahan
Mon Apr 17, 2017 9:03 pm
My Friend Tom, M0LTE recently built some APRS trackers using Pi zero W's and bits of other hardware. They were for a large scout hike where we needed to track support vehicles. They worked very well and I believe Tom is now working on an updated version on an arduino. I thought he had posted a blog about the raspberry pi tracker but maybe not. See his blog here about what he has done. Including an IGate: https://m0lte.uk/
James_jimjam
2E0JPM
Who is online
Users browsing this forum: No registered users and 12 guests
