import time
import datetime
import RPi.GPIO as GPIO
import os
#Bad readings.
BAD_READINGS = ["62", "125"]
#20 C is the ideal temp for now.
IDEAL_TEMP = 20000;
#Causes shutdown if temp gets this high
HIGH_TEMP = 22000;
#Seconds in twelve hours
TWELVE_HOURS = 43200
#Runs the shell script to make sure that the pins are setup.
BASH_COMMAND = "sudo ./pythongpiosetup.sh";
#Permissions for the files.
PERMISSION = "w+";
#Location of the temperature sensor.
SENSOR_LOCATION = "/sys/bus/w1/devices/28-0000040099fc/w1_slave";
#Location to write room stats.
OUTPUT_LOCATION = "roomstats.txt";
#Location of log file.
LOG_LOCATION = "log.txt";
#Location to write error messages to.
ERROR_LOCATION = "problems.txt";
#Pin that is connected to the fan.
FAN = 11;
#Pin that controls the light.
LIGHT = 12;
#Where the temp data starts for this sensor.
DATA_INDEX = 69;
#Delimiter for the data file.
DELIMITER = " ";
#Denotes an appliance is runnig.
ON = True;
#Denotes appliance is off.
OFF = False;
#Creates a new line.
NEW_LINE = "\n";
#Decimal char.
DECIMAL = '.';
#Divide by this number to get the correct decimal place in the temp.
FACTOR = 1000.0;
#Controls a light on a timer and a fan that is activated from the temperature.
class Controller():
def __init__(self, the_cycle):
os.system(BASH_COMMAND);
self.my_cycle = the_cycle;
self.setupPins();
self.my_data_file = open(OUTPUT_LOCATION, PERMISSION);
self.my_log = open(LOG_LOCATION, PERMISSION);
self.my_error_file = open(ERROR_LOCATION, PERMISSION);
self.my_light_on = OFF;
self.my_cycle_time = 0;
self.my_run_time = 0;
print "Initialization complete.";
return;
#Clears warnings because I dont have a way to clean up after termination.
def setupPins(self):
GPIO.setwarnings(OFF);
GPIO.setmode(GPIO.BOARD);
GPIO.setup(LIGHT, GPIO.OUT);
GPIO.setup(FAN, GPIO.OUT);
if not self.my_cycle:
GPIO.output(LIGHT, ON);
self.my_light_on = ON;
else:
GPIO.output(LIGHT, OFF);
GPIO.output(FAN, OFF);
print "Outputs set";
return;
#Gets the raw data from the sensor.
def getRawData(self):
file = open(SENSOR_LOCATION);
text = file.read();
file.close();
return text;
#grabs the temp out of the raw data.
def extractTemp(self, the_text):
return the_text[DATA_INDEX:the_text.__len__() - 1];
#Returns just the temp data.
def getTempData(self):
t0 = time.time();
ftext = self.extractTemp(self.getRawData());
self.isGoodRead(ftext);
self.setClocks(t0, time.time());
return ftext;
#Hack to filter bad values.
def isGoodRead(self, the_temp):
result = True;
for bad_temp in BAD_READINGS:
if the_temp == bad_temp:
result = False;
break;
return result;
#If room temp gets too high this method waits until the temp drops to
#the ideal temp in order to resume operation.
def coolDown(self, the_time, the_temp):
self.writeHighTempLogEntry(the_time, the_temp);
GPIO.output(FAN, ON);
if self.my_light_on:
temp = self.getTempData();
while int(temp) > IDEAL_TEMP:
self.writeData(self.my_run_time, temp);
self.my_error_file.write("HIGH TEMP CLEARED! Time: %s Temp: %s"%(self.dropDecimals(self.my_run_time), self.addDecimal(temp)));
return;
#Writes a helpful message to the error file if cooldown occured.
def writeHighTempLogEntry(self, the_time, the_temp):
self.my_error_file.write("HIGH TEMP! %s seconds. %s degrees C."%(self.dropDecimals(self.my_run_time), self.addDecimal(the_temp)));
self.my_error_file.write(NEW_LINE);
return;
#Cycles the light if the cycle time has been reached.
def checkLight(self, the_delta):
if the_delta > TWELVE_HOURS:
self.my_light_on = not self.my_light_on;
GPIO.output(LIGHT, self.my_light_on);
return;
#Turns the fan on if the temp is above the set point.
def checkFan(self, the_temp):
if int(the_temp) > HIGH_TEMP:
self.coolDown(time.time(), the_temp);
elif int(the_temp) > IDEAL_TEMP:
else:
return;
#Adds decimal point to the temp.
def addDecimal(self, the_temp):
temp = float(the_temp);
return str(temp / FACTOR);
#Writes data to the data file.
#run_time(in_seconds)\current temp * 1000 in celsius\true for fan running\true for light on.
def writeData(self, the_time, the_data):
self.my_data_file.write(str(the_time)[0:str(the_time).find('.')]);
self.my_data_file.write(DELIMITER);
self.my_data_file.write(the_data);
if GPIO.input(FAN) == 1:
self.my_data_file.write(str(ON));
else:
self.my_data_file.write(str(OFF));
if (self.my_light_on):
else:
self.my_data_file.write(NEW_LINE);
return;
#Sets the runtime and cycle clocks.
def setClocks(self, t0, t1):
elapsed = t1 - t0;
self.my_cycle_time += elapsed;
self.my_run_time += elapsed;
return;
#Drops decimal places.
def dropDecimals(self, the_number):
string = str(the_number);
return string[0:string.find(DECIMAL)];
#Starts the polling loop.
def start(self):
print "Running...";
while True:
temp_data = self.getTempData();
self.checkLight(self.my_cycle_time);
self.checkFan(temp_data);
self.writeData(self.my_run_time, temp_data);
self.my_data_file.close();
return;
Controller(True).start();
