ksharindam
platform independent c++ string length
Fri Dec 13, 2019 8:13 am
I am creating a cross platform program which has a pdf writer.
I am writing string like this,
    std::string header;
    header = "%PDF-1.4\n";
    int offset = header.size();
    std::ofstream stream;
    stream.open(filename);
    stream << header;
    stream.close();
in both linux and windows, the returned offset is 9. In linux number of actual written bytes is 9, but in windows it is 10.
This may be due to the different line ending types. linux uses LF and windows uses CRLF (\r\n).
How can I get the actual size of the string that is written?
Or how can I use only LF newline even in windows platform?
scotty101
Re: platform independent c++ string length
Fri Dec 13, 2019 8:33 am
Seems more like a question for stack overflow than a Raspberry Pi forum.
LdB
Fri Dec 13, 2019 8:53 am
tellp
http://www.cplusplus.com/reference/ostr ... eam/tellp/
In your case read the value stream.tellp();
njh
Fri Dec 13, 2019 11:35 am
It's not the question you asked, but: To write the identical PDF file on any platform (including a Pi) you should open a new file in binary mode and write the bytes required. Otherwise you will run into trouble when you write the "xref" section, or if you need any compressed or binary objects.
ksharindam
Fri Dec 13, 2019 11:50 am
tellp
Tried it, but it returns 9 in both windows and linux.
topguy
Fri Dec 13, 2019 12:16 pm
But you are saying that the file-size on Windows is 10 bytes ?
( I also think Njh had the best idea )
ksharindam
Fri Dec 13, 2019 12:21 pm
Thanks. It works.
I opened the file in binary mode using...
stream.open(filename, std::ios::out|std::ios::binary);
Return to “C/C++”
