ltb76
Webinterface - FLASK and while loop
Thu Dec 12, 2019 1:04 pm
My kid has been bugging me for a "Traffic light" in his room for a while. So when I stumbled upon an old traffic light on the local flea-market I thought it could be a fun project.
I have now hacked it together with a piZero and a relay. Besides a few powershell scripts I'm no programmer - this my my first fun with python.
My first step was to control the relay via python - I found several good scripts and hacked this together:
#!/usr/bin/python
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
pinList = [2, 3, 4]
#initialize
for i in pinList:
    GPIO.setup(i, GPIO.OUT)
    GPIO.output(i, GPIO.HIGH)
#time variables
SleepTimeL = 2
SleepTime5 = 5
SleepTime10 = 10
state = True
#traffic light loop
try:
 while True:
  GPIO.output(2, GPIO.LOW)
  print ("Red-ON")
  time.sleep(SleepTime10);
  GPIO.output(3, GPIO.LOW)
  print ("Yellow-ON")
  time.sleep(SleepTime5);
  GPIO.output(2, GPIO.HIGH)
  GPIO.output(3, GPIO.HIGH)
  print ("Red_Yellow-OFF")
  GPIO.output(4, GPIO.LOW)
  print ("Green-ON")
  print ("Yellow-ON")
  GPIO.output(4, GPIO.HIGH)
  print ("Green-OFF")
  print ("Yellow-OF")
#Cleanup - clean exit with keyboard interupt
except KeyboardInterrupt:
  print ("  Quit")
  GPIO.cleanup()
First I just fired the script via crontab at reboot. Worked like a charm.
Then the kid bugged me to be able start and top it. I then created a button on my sons tablet, when pressed it silently SSHs into the pi, executes the python script in a "screen session" and then exits. And another button to shoot down the script.
Now he would like to control the lights individually - sigh...
I was then thinking of doing a web interface - how hard could it be :)
So again I found a few projects using python, FLASK and nginx and tried getting it running.
My app.py looks like this:
from flask import Flask, render_template
import time
#import threading
#import logging
app = Flask(__name__)
GPIO.setmode (GPIO.BCM)
pinList = [2, 3, 4, 17, 9]
for i in pinList:
SleepTime2 = 0.2
SleepTime5 = 0.5
SleepTime10 = 0.10
light_on = False
#default route, without anything
def default():
        # read pin state
        #pin = GPIO.input(2)
        return render_template ('lights.html')
# set a route for action
@app.route("/<status>")
def onAction(status):
        if status == "off":
                print ("All Lights Off")
                light_on = False
                for i in pinList:
        if status == "red":
                print ("Blink - Red")
        if status == "yellow":
                print ("Blink - Yellow")
        if status == "green":
                print ("Blink - Green")
        if status == "blink":
                global light_on
                while light_on:
                        print ("blinking red")
                        time.sleep(SleepTime2);
                        print("Running trafficsignal")
if __name__ == "__main__":
        app.run(host='0.0.0.0', port=8080, debug=True)
Now the individual "buttons" work (red, yellow, greeen). But my blink button does not work. I assume it is the while loop that is not working.
Any hints would much appreciated.
And my apologies if the code is a mess :)
Thank you in advance.
paddyg
Re: Webinterface - FLASK and while loop
Fri Dec 13, 2019 6:16 pm
Do you need to set the global light_on True? You might need to put your actions into functions and run them in threads to stop the whole thing getting stuck in a flashing light loop. I think you have to put global as the first line of the function. Finally I think you can pass a list to gpio.setup so you don't need that loop
PS has something gone wrong with your indents at the end of the flash loop?
ltb76
Mon Dec 16, 2019 7:14 am
So I got it working. Now the code just needs to be tweaked and cleaned up.
Basically I created a baggrund thread to control the traffic light.
Bagground thread:
#!/usr/bin/python
import os
from os import path
import time
def threaded_task(traffic):
 print ("Traffic controller startet from: " + traffic + "...")
# init list with pin numbers
 pinList = [2, 3, 4]
# loop through pins and set mode and state to 'low'
 for i in pinList:
# time to sleep between operations in the main loop
 SleepTime2 = 2
 SleepTime5 = 5
 SleepTime10 = 10
 state = True
# main loop
 try:
  while True:
   time.sleep(0.5);
   print ("Trafficcontroller is running")
   while os.path.exists('/home/pi/relay/test.txt'):
    #GPIO.output(2, GPIO.LOW)
    print ("Running the traffic sequenze...")
    print ("Red-ON")
    time.sleep(4);
    print ("Yellow-ON")
    time.sleep(2);
    print ("Green-ON")
    time.sleep(4);
    print ("Yellow-ON")
    print ("Green-OFF")
    time.sleep(2);
    print ("Yellow-OFF")
 # GPIO.output(17, GPIO.HIGH)
#  GPIO.cleanup()
#  print ("Good bye!")
#End program cleanly with keyboard
   print ("  Quit")
   GPIO.cleanup()
The background thread is controlled from the main app.
import os
from os import path
from threading import Thread
from traffic import threaded_task
pinList = [2, 3, 4, 17]
relay_pin = 17
#pin state
pin = 1
if os.path.exists('/home/pi/relay/test.txt'):
 os.remove('/home/pi/relay/test.txt')
 #os.mknod('/home/pi/relay/test.txt')
for i in pinList:
#GPIO.setup (relay_pin, GPIO.OUT)
thread = Thread(target=threaded_task, args=("app01",))
thread.daemon = True
thread.start()
@app.route("/")
def default():
        # read pin state
        pin = GPIO.input(relay_pin)
        return render_template ('lights.html',pin=pin)
# light on or off
        pin = 2
        if status == "on":
                pin = 0
                GPIO.output (relay_pin, GPIO.LOW)
                if not os.path.exists('/home/pi/relay/test.txt'):
                #message =  "Light on!"
                print ("on")
        if status == "off":
                pin = 1
                for i in pinList:
                #message = "Light off!"
                print ("off")
        if status == "red-on":
                pin = 0
                GPIO.output (17, GPIO.HIGH)
                print ("red is on")
        # return to the template with new info
When pressing the "run" button it will create a "test.txt" file - and the bagground thread is looking for that.
It might not be pretty - but it works :)
PS: I based my script on this project (https://github.com/feiticeir0/lightup) - that gave me the framework :)
Return to “Python”
