chickennuggets
Floppy Disk Drive/ ADB to USB keyboard questions
Sun Dec 16, 2012 10:35 pm
I have a case from a DOA Apple III computer that I plan to put a Pi into. It has a 5.25 floppy drive, but I plan to just use standard 3.5s. I am also going to use an Apple keyboard, an ADB (Apple Desktop Bus, looks similar to an S-Video connector) to keep with the Apple theme. My main questions are: how would I go about setting up a floppy drive with a Pi if it's compatible and would an ADB keyboard work? (PS: I plan on using a regular internal floppy drive)
bugsy_malone 666
Re: Floppy Disk Drive/ ADB to USB keyboard questions
Mon Dec 24, 2012 7:59 pm
Well I recall trying to understand how this works previously, basically I think your answer is going to be USB.
whats your plan with using 3.5" disks? are you planning to use some sort of mac formatted, amiga formatted or PC?
Basiscally you can get a usb floppy drive for the PC so I would imagine theres a way to get that working (although I havent tried it myself yet and I have tons to learn about the pi yet), I dont know if CD drives work off the usb hub yet, (still learning) but basically I think if you plug in a powered usb hub inside your case you can add wifi/bluetooth/a hard drive/ other usb stuff.
As for the keyboard you can get a USB to ADB convertor, I have seen them online before as I think I was researching something to do with a connector on the back of an IMac monitor and you can get a usb to double ADB connector.
I just looked up an apple 3, man thats some old machine!
Sounds like your project is possible with a ton of usb convertors and stuff, good luck :)
chickennuggets
Sat Mar 23, 2013 7:21 pm
Thanks! I wasn't sure if the disk drive would work with a new computer such as the Pi, but good thing it does, as I have an armload of 3.5 disks I can use for it!
chickennuggets
Sat Mar 23, 2013 7:26 pm
Also, this is what my setup will look like: http://www.applematters.com/assets/imag ... 00x281.jpg I have both the case (which I have cleaned, gutted) and 2 monitors, one with the old rainbow Apple sticker which says "apple computer" in that funky lowercase font. I'm going to find a way to use the keycaps from the old keyboard, but if I can't, I'll just paint some keyboard brown and call it good.
