max11
Raspberry 4 not recognizing USB-Hub behind USB-switch
Wed Dec 04, 2019 8:45 pm
bear with me - this is nearly a short (?) story ... but i have the following problem:
I have a powered ush-hub.
Connected to the hub are
a Astrometa USB Tv stick and
a 2.5” harddisk.
This hub is connected to a USB-switch, by which the connection is directed either to a Raspberry Pi 3b+ (running Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux) or
Raspberry Pi 4b (running Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux)
Power adapter is the original Pi 5.1V 3A
Cable length is about 20 cm.
Switching to the Rpi 3b+ the hub is recognized and the correct devices are installed.
Switching to the Rpi 4 the hub is never connected (I tried USB3.0 and USB 2.0)
Switching the cables doesn’t help nor does switching the ports on the USB switch.
Raspberry Pi 3 always works – Raspberry 4 never. So any hardware problems (except for Raspi 4) can be excluded.
Output (short dmesg) when switching to Raspi 4
pi@raspberrypi:~ $ dmesg
[ 1333.805324] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 1334.715360] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 1334.715794] usb 1-1-port2: attempt power cycle
[ 1335.965412] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 1336.875422] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 1336.875835] usb 1-1-port2: unable to enumerate USB device
[ 1473.986324] usb 1-1.3: new high-speed USB device number 31 using xhci_hcd
[ 1474.896957] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1474.996346] usb 1-1.3: new high-speed USB device number 32 using xhci_hcd
[ 1475.906947] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1475.907382] usb 1-1-port3: attempt power cycle
[ 1477.156939] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1478.096964] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 1478.097398] usb 1-1-port3: unable to enumerate USB device
pi@raspberrypi:~ $
Output (short dmesg) when switching to Raspi 3
[ 8089.172448] usb 1-1.2: new high-speed USB device number 22 using dwc_otg
[ 8089.302836] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 8089.302852] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 8089.302862] usb 1-1.2: Product: USB 2.0 Hub
[ 8089.303583] hub 1-1.2:1.0: USB hub found
[ 8089.303672] hub 1-1.2:1.0: 4 ports detected
[ 8089.722459] usb 1-1.2.2: new high-speed USB device number 23 using dwc_otg
[ 8089.953447] usb 1-1.2.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 4.07
[ 8089.953463] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8089.953473] usb 1-1.2.2: Product: External Disk 3.0
[ 8089.953482] usb 1-1.2.2: Manufacturer: JMicron
[ 8089.953491] usb 1-1.2.2: SerialNumber: 0000000045A9
[ 8089.954317] usb 1-1.2.2: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 8089.954328] usb 1-1.2.2: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 8089.954340] usb-storage 1-1.2.2:1.0: USB Mass Storage device detected
[ 8089.954820] usb-storage 1-1.2.2:1.0: Quirks match for vid 152d pid 0578: 1000000
[ 8089.961600] scsi host1: usb-storage 1-1.2.2:1.0
[ 8090.162474] usb 1-1.2.3: new high-speed USB device number 24 using dwc_otg
[ 8090.402471] usb 1-1.2.3: New USB device found, idVendor=15f4, idProduct=0131, bcdDevice= 1.00
[ 8090.402487] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8090.402497] usb 1-1.2.3: Product: dvbt2
[ 8090.402507] usb 1-1.2.3: Manufacturer: astrometadvbt2
[ 8090.410098] usb 1-1.2.3: dvb_usb_v2: found a 'Astrometa DVB-T2' in warm state
[ 8090.479673] usb 1-1.2.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 8090.479717] dvbdev: DVB: registering new adapter (Astrometa DVB-T2)
[ 8090.487703] i2c i2c-3: Added multiplexed i2c bus 4
[ 8090.487717] rtl2832 3-0010: Realtek RTL2832 successfully attached
[ 8090.498316] mn88473 3-0018: Panasonic MN88473 successfully identified
[ 8090.498415] usb 1-1.2.3: DVB: registering adapter 5 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 8090.498647] usb 1-1.2.3: DVB: registering adapter 5 frontend 1 (Panasonic MN88473)...
[ 8090.498832] r820t 4-003a: creating new instance
[ 8090.505755] r820t 4-003a: Rafael Micro r820t successfully identified
[ 8090.505786] r820t 4-003a: attaching existing instance
[ 8090.510567] r820t 4-003a: Rafael Micro r820t successfully identified
[ 8090.522883] Registered IR keymap rc-empty
[ 8090.523041] rc rc0: Astrometa DVB-T2 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.3/rc/rc0
[ 8090.523252] input: Astrometa DVB-T2 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.3/rc/rc0/input9
[ 8090.523630] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
[ 8090.523869] usb 1-1.2.3: dvb_usb_v2: schedule remote query interval to 200 msecs
[ 8090.535053] usb 1-1.2.3: dvb_usb_v2: 'Astrometa DVB-T2' successfully initialized and connected
[ 8090.993244] scsi 1:0:0:0: Direct-Access JMicron Tech 0407 PQ: 0 ANSI: 6
[ 8090.994500] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 8090.994525] sd 1:0:0:0: [sdb] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 8090.995034] sd 1:0:0:0: [sdb] Write Protect is off
[ 8090.995052] sd 1:0:0:0: [sdb] Mode Sense: 47 00 00 08
[ 8090.995600] sd 1:0:0:0: [sdb] Disabling FUA
[ 8090.995617] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 8094.222482] sdb: sdb1
[ 8094.226198] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 8094.701046] usb 1-1.2.3: DVB: adapter 5 frontend 0 frequency 0 out of range (174000000..862000000)
pi@raspberrypi:~ $
When I connect without the USB-Switch everything is working fine:
Raspi 4:
[ 1637.767858] usb 1-1.3: new high-speed USB device number 35 using xhci_hcd
[ 1637.898278] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[ 1637.898294] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1637.898307] usb 1-1.3: Product: USB 2.0 Hub
[ 1637.914730] hub 1-1.3:1.0: USB hub found
[ 1637.915433] hub 1-1.3:1.0: 4 ports detected
[ 1638.327844] usb 1-1.3.2: new high-speed USB device number 36 using xhci_hcd
[ 1638.559230] usb 1-1.3.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 4.07
[ 1638.559246] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1638.559258] usb 1-1.3.2: Product: External Disk 3.0
[ 1638.559270] usb 1-1.3.2: Manufacturer: JMicron
[ 1638.559281] usb 1-1.3.2: SerialNumber: 0000000045A9
[ 1638.566812] scsi host0: uas
[ 1638.572301] scsi 0:0:0:0: Direct-Access JMicron Tech 0407 PQ: 0 ANSI: 6
[ 1638.574894] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
[ 1638.574910] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1638.575581] sd 0:0:0:0: [sda] Write Protect is off
[ 1638.575596] sd 0:0:0:0: [sda] Mode Sense: 5f 00 00 08
[ 1638.576501] sd 0:0:0:0: [sda] Disabling FUA
[ 1638.576517] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1638.577410] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 1638.664409] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1638.777797] usb 1-1.3.3: new high-speed USB device number 37 using xhci_hcd
[ 1639.017884] usb 1-1.3.3: New USB device found, idVendor=15f4, idProduct=0131, bcdDevice= 1.00
[ 1639.017892] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1639.017898] usb 1-1.3.3: Product: dvbt2
[ 1639.017903] usb 1-1.3.3: Manufacturer: astrometadvbt2
[ 1639.059105] usb 1-1.3.3: dvb_usb_v2: found a 'Astrometa DVB-T2' in warm state
[ 1639.131227] usb 1-1.3.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 1639.131250] dvbdev: DVB: registering new adapter (Astrometa DVB-T2)
[ 1639.144196] i2c i2c-7: Added multiplexed i2c bus 8
[ 1639.144204] rtl2832 7-0010: Realtek RTL2832 successfully attached
[ 1639.156365] mn88473 7-0018: Panasonic MN88473 successfully identified
[ 1639.156410] usb 1-1.3.3: DVB: registering adapter 5 frontend 0 (Realtek RTL2832 (DVB-T))...
[ 1639.156508] usb 1-1.3.3: DVB: registering adapter 5 frontend 1 (Panasonic MN88473)...
[ 1639.170952] r820t 8-003a: creating new instance
[ 1639.177956] r820t 8-003a: Rafael Micro r820t successfully identified
[ 1639.177967] r820t 8-003a: attaching existing instance
[ 1639.182765] r820t 8-003a: Rafael Micro r820t successfully identified
[ 1639.194378] Registered IR keymap rc-empty
[ 1639.194444] rc rc0: Astrometa DVB-T2 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.3/rc/rc0
[ 1639.194521] input: Astrometa DVB-T2 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.3/rc/rc0/input9
[ 1639.194681] rc rc0: lirc_dev: driver dvb_usb_rtl28xxu registered at minor = 0, raw IR receiver, no transmitter
[ 1639.194755] usb 1-1.3.3: dvb_usb_v2: schedule remote query interval to 200 msecs
[ 1639.208579] usb 1-1.3.3: dvb_usb_v2: 'Astrometa DVB-T2' successfully initialized and connected
[ 1639.208709] usbcore: registered new interface driver dvb_usb_rtl28xxu
[ 1641.796524] sda: sda1
[ 1641.809727] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1643.324024] usb 1-1.3.3: DVB: adapter 5 frontend 0 frequency 0 out of range (174000000..862000000)
pi@raspberrypi:~ $
My question is why hub and switch are working on the Raspberry Pi 3b+ but not on the Raspberry 4?
Complete dmesg Raspi 4 after boot:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 2019
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 256 MiB at 0x000000001c000000
[ 0.000000] On node 0 totalpages: 951296
[ 0.000000] DMA zone: 1593 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 181248 pages, LIFO batch:63
[ 0.000000] HighMem zone: 770048 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 949703
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M cma=256M video=HDMI-A-1:1280x720M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 smsc95xx.macaddr=DC:A6:32:5A:80:BD vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=5e3da3da-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3491992K/3805184K available (8192K kernel code, 661K rwdata, 2352K rodata, 2048K init, 850K bss, 51048K reserved, 262144K cma-reserved, 3080192K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xec800000 - 0xff800000 ( 304 MB)
lowmem : 0xc0000000 - 0xec400000 ( 708 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 662 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 28124 entries in 83 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000018] Switching to timer-based delay loop, resolution 18ns
[ 0.000238] Console: colour dummy device 80x30
[ 0.000261] console [tty1] enabled
[ 0.000304] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000326] pid_max: default: 32768 minimum: 301
[ 0.000586] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000603] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001336] CPU: Testing write buffer coherency: ok
[ 0.001734] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002361] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002514] rcu: Hierarchical SRCU implementation.
[ 0.003357] smp: Bringing up secondary CPUs ...
[ 0.004214] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005205] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006156] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006287] smp: Brought up 1 node, 4 CPUs
[ 0.006300] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006310] CPU: All CPU(s) started in HYP mode.
[ 0.006318] CPU: Virtualization extensions available.
[ 0.007055] devtmpfs: initialized
[ 0.017260] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.017458] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017477] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.024975] pinctrl core: initialized pinctrl subsystem
[ 0.025803] NET: Registered protocol family 16
[ 0.028548] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.030006] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.030017] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.030206] Serial: AMBA PL011 UART driver
[ 0.033237] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.069026] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.071406] vgaarb: loaded
[ 0.071780] SCSI subsystem initialized
[ 0.071966] usbcore: registered new interface driver usbfs
[ 0.072023] usbcore: registered new interface driver hub
[ 0.072116] usbcore: registered new device driver usb
[ 0.090376] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-09-24 17:34, variant start
[ 0.100106] raspberrypi-firmware soc:firmware: Firmware hash is cd3add54955f8fa065b414d8fc07c525e7ddffc8
[ 0.111623] clocksource: Switched to clocksource arch_sys_counter
[ 0.188700] VFS: Disk quotas dquot_6.6.0
[ 0.188776] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.188921] FS-Cache: Loaded
[ 0.189096] CacheFiles: Loaded
[ 0.189623] simple-framebuffer 3ea38000.framebuffer: framebuffer at 0x3ea38000, 0x1c2000 bytes, mapped to 0x(ptrval)
[ 0.189639] simple-framebuffer 3ea38000.framebuffer: format=r5g6b5, mode=1280x720x16, linelength=2560
[ 0.193160] Console: switching to colour frame buffer device 160x45
[ 0.196240] simple-framebuffer 3ea38000.framebuffer: fb0: simplefb registered!
[ 0.205185] NET: Registered protocol family 2
[ 0.205821] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.205846] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.205916] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.205986] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.206095] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.206124] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.206405] NET: Registered protocol family 1
[ 0.206930] RPC: Registered named UNIX socket transport module.
[ 0.206939] RPC: Registered udp transport module.
[ 0.206949] RPC: Registered tcp transport module.
[ 0.206958] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.206972] PCI: CLS 0 bytes, default 64
[ 0.209989] Initialise system trusted keyrings
[ 0.210163] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.219018] FS-Cache: Netfs 'nfs' registered for caching
[ 0.219499] NFS: Registering the id_resolver key type
[ 0.219530] Key type id_resolver registered
[ 0.219539] Key type id_legacy registered
[ 0.219558] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.221807] Key type asymmetric registered
[ 0.221817] Asymmetric key parser 'x509' registered
[ 0.221927] bounce: pool size: 64 pages
[ 0.221966] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.222120] io scheduler noop registered
[ 0.222130] io scheduler deadline registered (default)
[ 0.222280] io scheduler cfq registered
[ 0.222291] io scheduler mq-deadline registered (default)
[ 0.222301] io scheduler kyber registered
[ 0.245804] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.245823] brcm-pcie fd500000.pcie: could not get clock
[ 0.245883] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.245919] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 0.301658] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.301911] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.301926] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.301955] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.301996] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.302132] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.304854] PCI: bus0: Fast back to back transfers disabled
[ 0.304872] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.305079] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.305201] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.305513] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.308259] PCI: bus1: Fast back to back transfers disabled
[ 0.308274] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.308319] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.308338] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.308408] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.308425] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.308639] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.308804] pcieport 0000:00:00.0: Signaling PME with IRQ 56
[ 0.308958] pcieport 0000:00:00.0: AER enabled with IRQ 56
[ 0.309124] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.310933] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.312918] iproc-rng200 fe104000.rng: hwrng registered
[ 0.313138] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.313628] vc-sm: Videocore shared memory driver
[ 0.314015] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.323752] brd: module loaded
[ 0.333154] loop: module loaded
[ 0.333895] Loading iSCSI transport class v2.0-870.
[ 0.335526] libphy: Fixed MDIO Bus: probed
[ 0.335943] bcmgenet fd580000.genet: failed to get enet clock
[ 0.335958] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.335975] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.335991] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.336013] bcmgenet: Skipping UMAC reset
[ 0.336236] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.351651] libphy: bcmgenet MII bus: probed
[ 0.392176] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.393036] usbcore: registered new interface driver r8152
[ 0.393094] usbcore: registered new interface driver lan78xx
[ 0.393150] usbcore: registered new interface driver smsc95xx
[ 0.393445] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.393475] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.395700] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.396010] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 57
[ 0.396859] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.396873] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.396884] usb usb1: Product: xHCI Host Controller
[ 0.396895] usb usb1: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[ 0.396906] usb usb1: SerialNumber: 0000:01:00.0
[ 0.397408] hub 1-0:1.0: USB hub found
[ 0.397488] hub 1-0:1.0: 1 port detected
[ 0.397951] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.397973] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.397991] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.398392] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.398405] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.398417] usb usb2: Product: xHCI Host Controller
[ 0.398428] usb usb2: Manufacturer: Linux 4.19.75-v7l+ xhci-hcd
[ 0.398438] usb usb2: SerialNumber: 0000:01:00.0
[ 0.398920] hub 2-0:1.0: USB hub found
[ 0.398987] hub 2-0:1.0: 4 ports detected
[ 0.400165] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.425724] dwc_otg fe980000.usb: base=(ptrval)
[ 0.626026] Core Release: 2.80a
[ 0.626045] Setting default values for core params
[ 0.626070] Finished setting default values for core params
[ 0.826393] Using Buffer DMA mode
[ 0.826403] Periodic Transfer Interrupt Enhancement - disabled
[ 0.826412] Multiprocessor Interrupt Enhancement - disabled
[ 0.826422] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.826479] Dedicated Tx FIFOs mode
[ 0.827051] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = dc134000 dma = 0x00000000dc134000 len=9024
[ 0.827073] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.827084] dwc_otg: Microframe scheduler enabled
[ 0.827145] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.827162] WARN::hcd_init_fiq:458: FIQ ASM at c07b6224 length 36
[ 0.827178] WARN::hcd_init_fiq:497: MPHI regs_base at ec810200
[ 0.827213] dwc_otg fe980000.usb: DWC OTG Controller
[ 0.827242] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ 0.827275] dwc_otg fe980000.usb: irq 38, io mem 0x00000000
[ 0.827325] Init: Port Power? op_state=1
[ 0.827334] Init: Power Port (0)
[ 0.827590] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.827603] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.827614] usb usb3: Product: DWC OTG Controller
[ 0.827625] usb usb3: Manufacturer: Linux 4.19.75-v7l+ dwc_otg_hcd
[ 0.827635] usb usb3: SerialNumber: fe980000.usb
[ 0.828135] hub 3-0:1.0: USB hub found
[ 0.828183] hub 3-0:1.0: 1 port detected
[ 0.828766] dwc_otg: FIQ enabled
[ 0.828775] dwc_otg: NAK holdoff enabled
[ 0.828784] dwc_otg: FIQ split-transaction FSM enabled
[ 0.828797] Module dwc_common_port init
[ 0.828990] usbcore: registered new interface driver uas
[ 0.829098] usbcore: registered new interface driver usb-storage
[ 0.829255] mousedev: PS/2 mouse device common for all mice
[ 0.830410] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.830595] bcm2835-cpufreq: min=600000 max=1500000
[ 0.831138] sdhci: Secure Digital Host Controller Interface driver
[ 0.831147] sdhci: Copyright(c) Pierre Ossman
[ 0.831535] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.831961] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.834902] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.835039] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.835159] usbcore: registered new interface driver usbhid
[ 0.835168] usbhid: USB HID core driver
[ 0.835860] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.837151] [vc_sm_connected_init]: start
[ 0.843397] [vc_sm_connected_init]: end - returning 0
[ 0.844459] Initializing XFRM netlink socket
[ 0.844487] NET: Registered protocol family 17
[ 0.844606] Key type dns_resolver registered
[ 0.844988] Registering SWP/SWPB emulation handler
[ 0.845561] registered taskstats version 1
[ 0.845577] Loading compiled-in X.509 certificates
[ 0.853186] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.853248] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 0.856458] console [ttyS0] disabled
[ 0.856489] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 36, base_baud = 62500000) is a 16550
[ 0.856543] console [ttyS0] enabled
[ 0.856960] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.857463] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.858074] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.858085] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.882196] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ 0.899441] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.901031] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.902796] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.905677] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.907280] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.914533] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.917002] of_cfs_init
[ 0.917080] of_cfs_init: OK
[ 0.917652] Waiting for root device PARTUUID=5e3da3da-02...
[ 0.963702] random: fast init done
[ 0.971688] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.979228] mmc1: new high speed SDIO card at address 0001
[ 1.018808] mmc0: new ultra high speed DDR50 SDHC card at address 1234
[ 1.019846] mmcblk0: mmc0:1234 SA16G 14.4 GiB
[ 1.021095] mmcblk0: p1 p2
[ 1.058859] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.058900] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.065924] devtmpfs: mounted
[ 1.072156] Freeing unused kernel memory: 2048K
[ 1.072396] Run /sbin/init as init process
[ 1.154290] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.154305] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.154317] usb 1-1: Product: USB2.0 Hub
[ 1.156031] hub 1-1:1.0: USB hub found
[ 1.156344] hub 1-1:1.0: 4 ports detected
[ 1.526133] systemd[1]: System time before build time, advancing clock.
[ 1.643548] NET: Registered protocol family 10
[ 1.644722] Segment Routing with IPv6
[ 1.692082] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.692796] systemd[1]: Detected architecture arm.
[ 1.701066] systemd[1]: Set hostname to <raspberrypi>.
[ 1.703453] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 2.047019] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.047040] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.302274] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 2.421685] usb 1-1.3: new high-speed USB device number 4 using xhci_hcd
[ 2.461554] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.470435] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.476069] systemd[1]: Listening on Syslog Socket.
[ 2.476487] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.476895] systemd[1]: Listening on udev Kernel Socket.
[ 2.482113] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.483394] systemd[1]: Created slice User and Session Slice.
[ 2.574125] i2c /dev entries driver
[ 3.342229] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 3.342778] usb 1-1-port3: attempt power cycle
[ 3.996185] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.103242] systemd-journald[115]: Received request to flush runtime journal from PID 1
[ 4.592322] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 4.656405] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 4.657016] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 4.660271] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 4.662616] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 4.691733] usb 1-1.3: new high-speed USB device number 6 using xhci_hcd
[ 4.692301] usb 1-1.3: Device not responding to setup address.
[ 4.714123] media: Linux media interface: v0.10
[ 4.742498] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.746023] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.746044] [vc_sm_connected_init]: start
[ 4.751976] [vc_sm_connected_init]: installed successfully
[ 4.753775] videodev: Linux video capture interface: v2.00
[ 4.808451] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.810212] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.822975] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.846415] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.863244] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.863288] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.864331] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.872922] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.872953] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.881029] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.881060] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.882543] bcm2835_audio soc:audio: card created with 8 channels
[ 4.911931] usb 1-1.3: Device not responding to setup address.
[ 5.131681] usb 1-1.3: device not accepting address 6, error -71
[ 5.132069] usb 1-1-port3: unable to enumerate USB device
[ 5.202679] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.262780] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.262798] checking generic (3ea38000 1c2000) vs hw (0 ffffffffffffffff)
[ 5.262808] fb: switching to vc4drmfb from simple
[ 5.263012] Console: switching to colour dummy device 80x30
[ 5.268950] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 5.268964] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.268973] [drm] No driver support for vblank timestamp query.
[ 5.268982] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.383996] Console: switching to colour frame buffer device 160x45
[ 5.384038] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 5.420872] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.431687] usb 1-1.3: new high-speed USB device number 7 using xhci_hcd
[ 5.514128] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.555988] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.568572] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.569189] usbcore: registered new interface driver brcmfmac
[ 5.794923] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.808300] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 6.342304] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 6.441675] usb 1-1.3: new high-speed USB device number 8 using xhci_hcd
[ 7.352250] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 7.352686] usb 1-1-port3: attempt power cycle
[ 7.679911] random: crng init done
[ 7.679930] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.813008] uart-pl011 fe201000.serial: no DMA platform data
[ 8.086459] 8021q: 802.1Q VLAN Support v1.8
[ 8.389105] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.612283] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 9.522226] usb 1-1-port3: Cannot enable. Maybe the USB cable is bad?
[ 9.522639] usb 1-1-port3: unable to enumerate USB device
[ 9.678386] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.678405] brcmfmac: power management disabled
[ 10.125631] bcmgenet: Skipping UMAC reset
[ 10.222195] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 10.222352] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.998002] input: vnc-keyboard as /devices/virtual/input/input0
[ 10.998260] input: vnc-abspointer as /devices/virtual/input/input1
[ 10.998650] input: vnc-relpointer as /devices/virtual/input/input2
[ 11.271854] bcmgenet fd580000.genet eth0: Link is Down
[ 13.890858] input: vnc-keyboard as /devices/virtual/input/input3
[ 13.891105] input: vnc-abspointer as /devices/virtual/input/input4
[ 13.894285] input: vnc-relpointer as /devices/virtual/input/input5
[ 14.757568] Bluetooth: Core ver 2.22
[ 14.757610] NET: Registered protocol family 31
[ 14.757614] Bluetooth: HCI device and connection manager initialized
[ 14.757624] Bluetooth: HCI socket layer initialized
[ 14.757631] Bluetooth: L2CAP socket layer initialized
[ 14.757651] Bluetooth: SCO socket layer initialized
[ 14.777381] Bluetooth: HCI UART driver ver 2.3
[ 14.777390] Bluetooth: HCI UART protocol H4 registered
[ 14.777431] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.777544] Bluetooth: HCI UART protocol Broadcom registered
[ 15.059859] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.059863] Bluetooth: BNEP filters: protocol multicast
[ 15.059875] Bluetooth: BNEP socket layer initialized
[ 15.179721] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.994885] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 21.093775] Bluetooth: RFCOMM TTY layer initialized
[ 21.093799] Bluetooth: RFCOMM socket layer initialized
[ 21.093830] Bluetooth: RFCOMM ver 1.11
[ 21.395590] fuse init (API version 7.27)
pi@raspberrypi:~ $
pi@raspberrypi:~ $ lsusb -v
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idProduct 0x0003 3.0 root hub
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idVendor 0x2109 VIA Labs, Inc.
idProduct 0x3431 Hub
bcdDevice 4.20
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 4.19
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
pi@raspberrypi:~ $
pi@raspberrypi:~ $ uname -a
What can I do - besides leaving out the usb-switch?
FTrevorGowen
Re: Raspberry 4 not recognizing USB-Hub behind USB-switch
Wed Dec 04, 2019 9:02 pm
What model of USB switch? Can you post the output of:
lsusb
lsusb -t
with & w/o the switch on the P3B+ (that shorter form of the command makes it easier to find info. buried in the "noise" of your "full dump")
How (mechanically) do you switch between Pi's?
I have a similar issue in that this device: https://www.cpmspectrepi.uk/raspberry_p ... ngHub.html is now ~7 years old and does not always switch cleanly (and its indicator leds sometimes "lie") between my Gigabyte Brix box and whatever Pi I have connected and I am awaiting delivery of a simpler (mechanical switch only?) device to test.
Trev.
max11
Thu Dec 05, 2019 12:20 am
Hi Trev,
it is a mechanical device, which i already checked for loose soldering - all connected (and it can be assured by connecting the Raspi 3b+ on each port.
https://www.aliexpress.com/item/4000025738015.html
lsusb and lsusb -t RasPi 3b+ (not connected):
Bus 001 Device 007: ID 0781:5583 SanDisk Corp.
Bus 001 Device 005: ID 0c45:7000 Microdia
Bus 001 Device 009: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
pi@raspberrypi:~ $ lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 9, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
|__ Port 2: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 7, If 0, Class=Mass Storage, Driver=usb-storage, 480M
pi@raspberrypi:~ $
USB-Switch connected:
Bus 001 Device 016: ID 15f4:0131 HanfTek
Bus 001 Device 015: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp.
Bus 001 Device 014: ID 1a40:0101 Terminus Technology Inc. Hub
pi@raspberrypi:~ $
|__ Port 2: Dev 14, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 16, If 0, Class=Vendor Specific Class, Driver=dvb_usb_rtl28xxu, 480M
|__ Port 3: Dev 16, If 1, Class=Vendor Specific Class, Driver=, 480M
|__ Port 2: Dev 15, If 0, Class=Mass Storage, Driver=usb-storage, 480M
pi@raspberrypi:~ $
(I was afraid that the HD needed too much power, so i also disconnected it - but that doesn't change the result)
andersdk
Thu Dec 05, 2019 12:29 am
Is the connected USB harddisk powered solely by the USB hub?
I suspect this could be a problem, as not all hubs are up to the job supplying the USB norm power on each port.
It could also be the PSU unit you are powering the hub with, that are a bit too weak.
max11
Thu Dec 05, 2019 10:38 am
As i said above, i also tried to connect the hub without the HD being connected - so the HD is not to blame. And i also said that i am using the original Raspberry Pi 4 power adapter.
