jdb
VL805 firmware release 0137ac - improved USB downstream power switching
Wed Dec 04, 2019 8:27 pm
We've received an updated firmware from VLI that allows for port power control, i.e. turning off downstream USB devices.
The attached zip file contains an updated firmware and patch file. Note: rebooting is required after flashing the new firmware.
EDIT: firmware superseded by 0137ad - please use this firmware and the rpi-eeprom-update facility instead.
https://www.raspberrypi.org/forums/view ... 2#p1595188
Step 1: Flash the firmware to the VLI EEPROM:
# if not already installed, install the rpi-eeprom package:
sudo apt install rpi-eeprom
sudo vl805 -w vl805_fw_0137ac.bin
sudo reboot
Step 2: build uhubctl
uhubctl can be used to manipulate port power - but needs patching to allow switching of ganged port power. Copy the code patch in the zipfile to the uhubctl directory and apply the patch as shown below. Build, patch and install uhubctl with:
sudo apt install libusb-1.0-0-dev
git clone https://github.com/mvp/uhubctl
cd uhubctl
# copy the attached patchfile from the zip to the uhubctl directory
git apply uhubctl.patch
make
sudo make install
Step 3:
To power off the downstream ports, both the internal USB2 hub and USB3 root hub need to be powered off, as the external power control pin ORs the two hub power controls together.
Power off:
sudo uhubctl -e -a 0 -l 2
sudo uhubctl -e -a 0 -l 1-1
power on:
sudo uhubctl -e -a 1 -l 2
sudo uhubctl -e -a 1 -l 1-1
Please test and report back.
vl805_fw_0137ac.zip
(41.44 KiB) Downloaded 1161 times
Rockets are loud.
https://astro-pi.org
Jochem
Re: VL805 firmware release 0137ac - improved USB downstream power switching
Wed Dec 04, 2019 9:26 pm
Reporting back:
1. FW install OK:
pi@R4DNSUnifi:~/uhubctl $ sudo rpi-eeprom-update
BOOTLOADER: up-to-date
CURRENT: ma 18 nov 2019 11:06:55 UTC (1574075215)
 LATEST: ma 18 nov 2019 11:06:55 UTC (1574075215)
VL805: update required
CURRENT: 000137ac
 LATEST: 000137ab
2. patching does not work:
pi@R4DNSUnifi:~/uhubctl $ git apply uhubctl.patch
error: patch failed: uhubctl.c:413
error: uhubctl.c: patch does not apply
Fyi:
pi@R4DNSUnifi:~/uhubctl $ ls -l
totaal 100
-rw-r--r-- 1 pi pi 18092 dec  4 22:02 COPYING
drwxr-xr-x 2 pi pi  4096 dec  4 22:02 Formula
-rw-r--r-- 1 pi pi   706 dec  4 22:02 LICENSE
-rw-r--r-- 1 pi pi  1157 dec  4 22:02 Makefile
-rw-r--r-- 1 pi pi 18294 dec  4 22:02 README.md
-rw-r--r-- 1 pi pi 34771 dec  4 22:02 uhubctl.c
-rw-r--r-- 1 pi pi   543 dec  4 22:02 uhubctl_git.bb
-rw-r--r-- 1 pi pi   916 dec  4 20:35 uhubctl.patch
-rw-r--r-- 1 pi pi    11 dec  4 22:02 VERSION
pi@R4DNSUnifi:~/uhubctl $ cat VERSION
v2.1.0-dev
After patching by hand, make and make install and powering off:
pi@R4DNSUnifi:~/uhubctl $ sudo uhubctl -e -a 0 -l 2
Current status for hub 2 [1d6b:0003 Linux 4.19.75-v7l+ xhci-hcd xHCI Host Controller 0000:01:00.0, USB 3.00, 4 ports]
  Port 1: 02a0 power 5gbps Rx.Detect
  Port 2: 02a0 power 5gbps Rx.Detect
  Port 3: 02a0 power 5gbps Rx.Detect
  Port 4: 02a0 power 5gbps Rx.Detect
Sent power off request
New status for hub 2 [1d6b:0003 Linux 4.19.75-v7l+ xhci-hcd xHCI Host Controller 0000:01:00.0, USB 3.00, 4 ports]
  Port 1: 0080 off
  Port 2: 0080 off
  Port 3: 0080 off
  Port 4: 0080 off
pi@R4DNSUnifi:~/uhubctl $ sudo uhubctl -e -a 0 -l 1-1
Current status for hub 1-1 [2109:3431 USB2.0 Hub, USB 2.10, 4 ports]
  Port 1: 0100 power
  Port 2: 0100 power
  Port 3: 0100 power
  Port 4: 0100 power
New status for hub 1-1 [2109:3431 USB2.0 Hub, USB 2.10, 4 ports]
  Port 1: 0000 off
  Port 2: 0000 off
  Port 3: 0000 off
  Port 4: 0000 off
All looks good. But according to my POE port, the same power is delivered before and after, in my case 3,5 watt
trejan
Thu Dec 05, 2019 12:03 am
What do you have plugged into the USB ports?
jdb
Thu Dec 05, 2019 7:38 pm
It goes without saying that you won't notice any device power savings unless you have devices in your USB ports...
The
Patch got mangled with DOS line endings (doh). Will fix and post when updated.
Rockets are loud.
Jochem
Thu Dec 05, 2019 8:49 pm
I expected a "power down" of the VL805 chip and maybe a big saving like the 200mA with the 3B as is discussed in other threads. Using only ethernet and trying to minimize power drawn by shutting of the main consumers, like WiFi and -i hoped- USB.
Clearly, i missed the "port power control" of the op. Sorry for that..
Jochem
Thu Dec 05, 2019 9:08 pm
Anyhow, it seems to work. Baseline 3.5W. After attaching a device the Pi draws 4.2W, shutting the ports off brings it back to the baseline.
tvjon
Thu Dec 05, 2019 11:02 pm
Current status for hub 2 [1d6b:0003 Linux 4.19.86-v7l+ xhci-hcd xHCI Host Controller 0000:01:00.0, USB 3.00, 4 ports]
Port 1: 0203 power 5gbps U0 enable connect [0480:a202 TOSHIBA External USB 3.0 20160312012904F]
New status for hub 2 [1d6b:0003 Linux 4.19.86-v7l+ xhci-hcd xHCI Host Controller 0000:01:00.0, USB 3.00, 4 ports]
Port 1: 0080 off
Port 2: 0080 off
Port 3: 0080 off
Port 4: 0080 off
Port 1: 0503 power highspeed enable connect [0480:a202 TOSHIBA External USB 3.0 20160312012904F]
Port 2: 0100 power
Port 3: 0100 power
Port 4: 0100 power
Port 1: 0000 off
Port 2: 0000 off
Port 3: 0000 off
Port 4: 0000 off
$ sudo uhubctl -e -a 1 -l 2
Port 1: 0080 off
Port 2: 0080 off
Port 3: 0080 off
Port 4: 0080 off
Sent power on request
$ sudo uhubctl -e -a 1 -l 1-1
Port 1: 0000 off
Port 2: 0000 off
Port 3: 0000 off
Port 4: 0000 off
Port 1: 0100 power
Port 2: 0100 power
Port 3: 0100 power
Port 4: 0100 power
In the file manager, a replicated disc icon appears. Clicking on it produces the error window attached.
duplicateMount Icon.png (9.78 KiB) Viewed 3348 times
trejan
Thu Dec 05, 2019 11:06 pm
You need to unmount your HD first. Turning off the port power is roughly equivalent to you pulling out the USB plug of your Toshiba HD.
tvjon
Thu Dec 05, 2019 11:10 pm
The only reason I mentioned it was because I *did* unmount the disc as I normally do, before issuing the relevant commands.
However 2 disc icons appeared back.
Also note the spelling error in the window message.
trejan
Thu Dec 05, 2019 11:54 pm
Oops. Sorry. Does dmesg say anything? Did it start on sda or sdb?
fik
Fri Dec 06, 2019 9:31 am
What about unmounting and then ejecting the disk before stopping the power?
echo 1 > /sys/block/sdx/device/delete
andrum99
Fri Dec 06, 2019 5:05 pm
Is this firmware update intended to allow Linux to automatically save power by switching off certain USB ports, or will this always need a manual twiddle?
trejan
Fri Dec 06, 2019 5:22 pm
No. It is for people that want to power cycle their USB devices. All of the ports get turned off/on together though.
Yep.
goodburner
Sun Dec 08, 2019 6:13 am
git apply --ignore-space-change --ignore-whitespace uhubctl.patch
adding --ignore-space-change --ignore-whitespace works for applying the patch.
Gavinmc42
Sun Dec 08, 2019 7:58 am
Could be useful for USB powered Pi Zero's when they are USB booting.
Not sure if there will be mouse/keyboard conflicts, test via VNC?
I'm dancing on Rainbows.
jdb
Mon Dec 16, 2019 1:04 pm
Patchfile is fixed.
Rockets are loud.
Return to “Advanced users”
