Dazzathedrummer
Stream Pi audio to Apple TV (airplay)
Wed Dec 04, 2019 1:38 pm
My home hifi equipment is centered around Apple TV. I've got Plex running on a Pi3 and I use the Apple TV Plex app to stream my personal music collection.
I have quite a few vinyl albums and my turntable is situated across the room from my amplifier - so I have to either move the turntable or plug in long cables to play vinyl.
I'm wondering if its possible to stream the audio from the turntable (turntable into a pre-amp, so the signal is line level) to the apple TV via a Pi?
Is there an Apple TV app that will pick up the audio or can I airplay the Pi to the ATV?
Thanks,
Darren
Re: Stream Pi audio to Apple TV (airplay)
Wed Dec 04, 2019 7:13 pm
Thanks,
Darren
The Raspberry Pi SBC does not have any Audio Inputs !!
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
Dazzathedrummer
Wed Dec 04, 2019 7:33 pm
Yes, sorry, I mean...assuming I give it an audio input with a hifiberry for example.
epoch1970
Wed Dec 04, 2019 8:22 pm
Suddenly I’m not so clear with what shairplay-sync is, but I think it only works as a sink (in sync)
What you want is a source, this looks to be one, maybe there are other options?
Man in a van
Sat Dec 07, 2019 11:20 am
Thanks,
Darren
This might give you a few ideas (read through all the thread).
https://forums.slimdevices.com/showthre ... -receivers
The link referenced by epoch1970 is, I think, a LMS Plugin by philippe_44.
ronnie
Dazzathedrummer
Sat Dec 07, 2019 11:40 am
I've just read that Icecast can do it - I'm going to check that route out.
Return to “Media centres”
