IdiotOfThings
TV hat - case and adapter issues
Wed Nov 27, 2019 9:15 pm
Hi
I recently bought a Pi TV hat which came with an adapter for the coax cable - does anyone know what type the small end connector (on the board) is called? It looks like an small SMA connector, but doesn't have a thread. I have found the connection to be quite "fragile" to the slightest movement of the cable/adapter. I would like to have a small fly lead going direct from it which I can fix to the case. Sort of part two to my question - is there a Pi TV hat case? Does it hold the adapter more firmly in place? I haven't been able to find one yet...
Cheers
Ben
trejan
Re: TV hat - case and adapter issues
Wed Nov 27, 2019 10:25 pm
MCX
You can buy short MCX leads as MCX is fairly popular on smaller USB TV receiver dongles. I'm not sure how easy it would be to find a panel mount connector on the other end though.
No official case but Pi Hut have their ModMyPi brand TV HAT case. The adapter just sits in a large hole in the case though. It isn't retained by anything.
IdiotOfThings
Fri Nov 29, 2019 12:54 pm
Many thanks, perfect answers! 10/10!
I think I have found an MCX to F-type pigtail that should do the job now, I just want to take a bit of the strain off the board itself. Hopefully there won't be any loss by doing so - the tuner/board itself seems quite sensitive to signal strength compared to some.
Cheers
Ben
Pulsar33
Wed Dec 04, 2019 8:18 am
Hello
It's quite easy to do :
Best regards
Pulsar33
Pi 4 with 4Gb memory, DVB TV pHAT ------------------- Desktop : Core i5 Linux MINT 19.2
IdiotOfThings
Wed Dec 04, 2019 10:01 pm
Very neat! Might go that route and put a dab of hot glue where the connectors join.
