nick8967
Android application showing real time data
Tue Nov 26, 2019 2:50 pm
So, I am trying to build an application in android that I need to read data from a Raspberry wirelessly. I am searching on google but I got confused. Can I read data from the wifi of the Raspberry? Should I run a more specific application on RaspberryPi? Should I go better to bluetooth? I don't know how to construct the whole thing...
Another alternative I am thinking is to connect the Raspberry to the ethernet and run it as a server. So I visit the IP address of the Raspberry Pi and get the data with the android app..Does this make sense?
neilgl
Re: Android application showing real time data
Tue Nov 26, 2019 3:36 pm
Yes you can read data from the pi via WiFi. Let us say the phone and pi are connected to the same network via wifi
You could install mqtt on the pi to publish a topic that contains the data you want, then the android app subscribes to that topic to get the data.
Or set the pi up as a webserver (e.g. apache2 or nginx or flask) and "visit" it to get the data.
And there are many other ways...
You could also set the pi as an access point (create a WiFi SSID for it) and connect to that with your phone.
nick8967
Tue Nov 26, 2019 3:51 pm
What about Kafka? Can be run on RaspberryPi?
DirkS
Tue Nov 26, 2019 3:53 pm
I don't think he runs anywhere these days
https://www.wikiwand.com/en/Franz_Kafka
neilgl
Wed Nov 27, 2019 10:19 am
Yes looks like Kafka and Zookeeper can run on a pi4 - though I have not done it myself yet.
Return to “Android”
