paiku
apparmor on Raspbian
Fri Nov 22, 2019 4:31 pm
Is apparmor enabled on Raspbian by default like Debian 10 (buster)? Are some special instructions needed to enable it properly for Raspbian, is it even recommended to use on a Pi? (my Pi is a 3B+)
Pulsar33
Re: apparmor on Raspbian
Fri Nov 22, 2019 4:53 pm
Apparmor was (is) not loaded by the kernel. I made a report : https://github.com/raspberrypi/linux/issues/3196
This one (3196) was closed because an old thread (1698) was open about that problem.
That thread (1698) has been relaunched, the work has been done and tested, then proposed for merging.
You can say there that your are also waiting for this : https://github.com/raspberrypi/linux/pull/1698
In the meantime, you have to recompile the kernel if you want to use apparmor. Read mainly this message
Best regards
Pulsar33
Pi 4 with 4Gb memory, DVB TV pHAT ------------------- Desktop : Core i5 Linux MINT 19.3
paiku
Fri Nov 22, 2019 5:40 pm
This is very informative, thank you. ^^ I'm not that technically adept either, but having any kind of tool to passively (and reliably?) keep my system from being easier to exploit, the better.
I'll keep an eye on that github thread, it would be interesting to get other benchmarks from earlier Pi models as well. At minimum, the stronger processor on the new Pi 4 would benefit from integrating apparmor by default in the kernel.
Return to “Raspberry Pi OS”
