I have a few bits on order and some of them will work within the 3.3v and 5v range that i am playing around with. I have an anker 8400mah 5v 1/2amp battery pack to power the PI.
Basically the Pi has a 5v pin (pin 2) can I draw power from this? I have an infrared sensor which uses a 5v input. Can i use the 2nd pin and then connect it to pin 6 gnd. With the third connection connected to any of the other input GPIO pins to read the High/LOW signal?
The alternative is just to splice a USB cable and plug that into the breadboard direct to power these components.
