Strato_54
Help with Emteria and 3B
Sun Nov 17, 2019 2:19 am
I am using Emteria OS which is an Android distro for the pis, and im running it on my 3 Model B. At times it is severly slow and was hoping for tips to make it a bit snappier. Does this OS run on the new 4, or the B+ and if so for either how much of a better experience is it? I was thinking that my monitor might be causing it to be a bit slow but the res is only set to 720p. I am using it on a 21.5" 1080 60 display but am hoping to use the OS on the 7" touch screen when i am able to purchase the screen. Could this be a factor in it running rough?
pcmanbob
Re: Help with Emteria and 3B
Sun Nov 17, 2019 10:57 am
As android is generally not supported here, and Emteria OS appears to be a commercial product I suggest you as for help from the supplier/creator of this particular version of android.
https://forum.emteria.com/
Return to “Android”
