Atah
raspbian boot error
Fri Dec 14, 2012 2:48 pm
Hello, I 'm french and I despaired ;(
After update in commande sudo apt-get update .My raspberry does not start on the system.
Here are the errors presented:
fsck died with status 4
failed (code 4)
The root filesystem is currently mounted in read-only...
I need help please
IMG_0099 (2).jpg (44.92 KiB) Viewed 911 times
mislavpongrac
Re: raspbian boot error
Fri Aug 16, 2013 9:54 am
i have the same problem with faild (code 4), plase write the solution.
Thnx.
Joe Schmoe
Fri Aug 16, 2013 12:01 pm
mislavpongrac wrote:i have the same problem with faild (code 4), plase write the solution.
Thnx.
It looks like the SD card is munged.
Possible solutions include:
1) Doing a manual fsck in the maintenance shell on the Pi. That may fix things.
2) Doing a manual fsck in the maintenance shell on another Linux box. That may fix things.
3) Re-imaging the card. That may fix things.
4) Getting a new card or a new Pi.
mislavpongrac
Fri Aug 16, 2013 12:07 pm
Thnx.
Tnx for your reply, but i solve it :) i was too blind to see that it said me what to do :P
But tnx again for yor reply :)
drgeoff
Fri Aug 16, 2013 10:47 pm
mislavpongrac wrote:Tnx for your reply, but i solve it :) i was too blind to see that it said me what to do :P
Please report the solution. Might help someone else in the future.
