SalvatoreAD
[RPi4] Webcam usb freeze os - input/output
Tue Nov 12, 2019 9:16 pm
hi everyone, I have a Raspberry Pi 4 with 4GB of RAM.
when i connect a usb webcam, the operating system slows down and every input device like mouse and keyboard don't work. when I disconnect the webcam, the operating system works.
Can you help me?
[email protected]:~ $ vcgencmd version
Sep 24 2019 17:34:30
Copyright (c) 2012 Broadcom
version cd3add54955f8fa065b414d8fc07c525e7ddffc8 (clean) (release) (start)
[email protected]:~ $ cat /boot/.firmware_revision
63c1855a491efa4c42d7889065d17af7dd6c51db
This is kernel
[email protected]:~ $ uname -a
Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
a-sheng
Re: [RPi4] Webcam usb freeze os - input/output
Thu Nov 28, 2019 8:29 am
is YUYv422 bug. on V4l2
you can try qv4l
sudo apt install qv4l2
in MJPG(Motion-JPEG) is OK.
crnewton
Mon Jan 06, 2020 8:47 am
I have the same issue. anyone found a solution for this? (qv4l2 did not solve the problem for me)
jdb
Mon Jan 06, 2020 10:03 am
Rockets are loud.
https://astro-pi.org
crnewton
Mon Jan 06, 2020 11:08 am
@jdb VL805 0137d did not help.
howeveri just found a fix for me, if i do the following manual steps:
sudo apt-get install pciutils
sudo setpci -s 01:00.0 0xD4.B=0x41
This will resolve the issue of lagg and key sticking on usb devices (when using a usb webcam).
explaination (from https://linux.die.net/man/8/setpci):
-s [[[[<domain>]:]<bus>]:][<slot>][.[<func>]]
with the tool setpci we write a byte (B) with the value '0x41' to register '0xD4'.
we write to:
domain: 01, bus: 00, slot: 0
I dont know why this value and register, I hope someone can answer that for me.
In my case it resolved the usb lagg & key sticking 100%.
jdb
Mon Jan 06, 2020 12:06 pm
Please post the output of lsusb -t and sudo lsusb -v.
Rockets are loud.
crnewton
Mon Jan 06, 2020 12:37 pm
(on a setup without the firmware patch (you linked), setpci command executed, webcam connected & busy)
lsusb -t :
[email protected]:~ $ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 3, Class=Video, Driver=uvcvideo, 480M
|__ Port 1: Dev 3, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 3, If 2, Class=Video, Driver=uvcvideo, 480M
|__ Port 1: Dev 3, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
lsusb -v:
https://pastebin.com/rbaFY0X9
