scyto
WIFI Crash net/wireless/sme.c:752 __cfg80211_connect_result+0x3c0/0x410 [cfg80211]
Mon Nov 11, 2019 3:11 am
This is my first PI4 2gb, install from latest raspbian a week or so ago.
Raspbian Linux version 4.19.75-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1270 SMP Tue Sep 24 18:51:41 BST 2019
Built in wifi WLAN0
It has been dropping off the netywork after a few hours.
I seem to get these stack traces everytime:
Nov 10 03:03:54 genmon kernel: [125997.788087] ------------[ cut here ]------------
Nov 10 03:03:54 genmon kernel: [125997.788183] WARNING: CPU: 0 PID: 6804 at net/wireless/sme.c:752 __cfg80211_connect_result+0x3c0/0x410 [cfg80211]
Nov 10 03:03:54 genmon kernel: [125997.788187] Modules linked in: 8021q garp stp llc rtc_ds1307 brcmfmac brcmutil sha256_generic cfg80211 raspberrypi_hwmon hwmon rfkill snd_bcm2835(C) snd_pcm snd_timer snd bcm2835_codec(C) v4l2_mem2mem bcm2835_v4l2(C) bcm2835_mmal_vchiq(C) i2c_bcm2835 videobuf2_dma_contig v4l2_common videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev media vc_sm_cma(C) rpivid_mem uio_pdrv_genirq fixed uio i2c_dev ip_tables x_tables ipv6
Nov 10 03:03:54 genmon kernel: [125997.788333] CPU: 0 PID: 6804 Comm: kworker/u8:2 Tainted: G        WC        4.19.75-v7l+ #1270
Nov 10 03:03:54 genmon kernel: [125997.788336] Hardware name: BCM2835
Nov 10 03:03:54 genmon kernel: [125997.788389] Workqueue: cfg80211 cfg80211_event_work [cfg80211]
Nov 10 03:03:54 genmon kernel: [125997.788410] [<c0212d10>] (unwind_backtrace) from [<c020d530>] (show_stack+0x20/0x24)
Nov 10 03:03:54 genmon kernel: [125997.788418] [<c020d530>] (show_stack) from [<c097fb20>] (dump_stack+0xd4/0x118)
Nov 10 03:03:54 genmon kernel: [125997.788426] [<c097fb20>] (dump_stack) from [<c0222330>] (__warn+0x104/0x11c)
Nov 10 03:03:54 genmon kernel: [125997.788434] [<c0222330>] (__warn) from [<c0222480>] (warn_slowpath_null+0x50/0x58)
Nov 10 03:03:54 genmon kernel: [125997.788489] [<c0222480>] (warn_slowpath_null) from [<bf41f6fc>] (__cfg80211_connect_result+0x3c0/0x410 [cfg80211])
Nov 10 03:03:54 genmon kernel: [125997.788593] [<bf41f6fc>] (__cfg80211_connect_result [cfg80211]) from [<bf3ef39c>] (cfg80211_process_wdev_events+0x104/0x160 [cfg80211])
Nov 10 03:03:54 genmon kernel: [125997.788694] [<bf3ef39c>] (cfg80211_process_wdev_events [cfg80211]) from [<bf3ef438>] (cfg80211_process_rdev_events+0x40/0x98 [cfg80211])
Nov 10 03:03:54 genmon kernel: [125997.788792] [<bf3ef438>] (cfg80211_process_rdev_events [cfg80211]) from [<bf3e92d4>] (cfg80211_event_work+0x24/0x2c [cfg80211])
Nov 10 03:03:54 genmon kernel: [125997.788846] [<bf3e92d4>] (cfg80211_event_work [cfg80211]) from [<c023db40>] (process_one_work+0x170/0x458)
Nov 10 03:03:54 genmon kernel: [125997.788854] [<c023db40>] (process_one_work) from [<c023de84>] (worker_thread+0x5c/0x5a4)
Nov 10 03:03:54 genmon kernel: [125997.788860] [<c023de84>] (worker_thread) from [<c0244170>] (kthread+0x138/0x168)
Nov 10 03:03:54 genmon kernel: [125997.788866] [<c0244170>] (kthread) from [<c02010ac>] (ret_from_fork+0x14/0x28)
Nov 10 03:03:54 genmon kernel: [125997.788870] Exception stack(0xeb15bfb0 to 0xeb15bff8)
Nov 10 03:03:54 genmon kernel: [125997.788874] bfa0:                                     00000000 00000000 00000000 00000000
Nov 10 03:03:54 genmon kernel: [125997.788879] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Nov 10 03:03:54 genmon kernel: [125997.788883] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
Nov 10 03:03:54 genmon kernel: [125997.788893] ---[ end trace 77c2645e50b9a632 ]---
A google search did turn this old article up but i don't know if it applies as i have no idea what an orange pi is?
https://forum.armbian.com/topic/8408-or ... ct_result/
Does this look like the same issue (note my network does support `Unscheduled Automatic Power Save Delivery` and 80211r roaming.
Thee fixed in the linked post doesn't seem to be applicable to a pi?
The command
journalctl | grep brcmfmac
seems to apply power saving is off at chipset level.
the command
iw wlan0 get power_save
implies power saving is on.
I will try adding
 /sbin/iwconfig wlan0 power off
to rc.local
Bottom line I am super confused is power management is on, off or anything to do with this issue or not!?
What can I do next to collect logs etc?
scyto
Re: WIFI Crash net/wireless/sme.c:752 __cfg80211_connect_result+0x3c0/0x410 [cfg80211]
Mon Nov 11, 2019 4:12 am
a github issue with the same connect_result
at least 3 folks seeing this
https://github.com/raspberrypi/linux/issues/3318
scyto
Tue Nov 12, 2019 7:27 pm
I have tried disabling a slew of settings on my wifi equipment that are new or experimental - this has not resolved this issue.
Any suggestions?
scyto
Thu Nov 21, 2019 5:18 pm
I think this crash was not causing my issue (and it went away after i moved the pi to a 802.11b network with WPA2 TKIP and no rekeying or Unscheduled Power Delivert).
My issue seems to have been caused bu the pi failing to renew its DHCP address at or before leas expiration - the lease time was 31 minutes.
Given the number of github and forum issues around DHCP leases / ARP issues (i believe the ARPs stop because the DHCP lease expires, it may also be related to carrier issues - but it affectst both wired and wlan) i just manually configured my IP on the pi. It has been rock solid since i did that
Hope this helps someone else.
note my DHCP server is windows 2019 - it appeared to be issuing the DHCP ACKs ok.
