richie47
8 bits-per-pixel mode on the R4b
Sat Nov 09, 2019 3:56 pm
Has anyone successfully put the raspi 4b into an 8 bit-per-pixel mode?
I was successful using this code on the 3b, but the following fails for the 4b.
vinfo.bits_per_pixel = 8;
if (ioctl(fbfd, FBIOPUT_VSCREENINFO, &vinfo)) {
		printf("Error setting variable information.\n");
		return 1;
thanks,
Richie
6by9
Re: 8 bits-per-pixel mode on the R4b
Sun Nov 10, 2019 4:04 pm
By default previous Pi variants all used bcm2708_fb as the driver for the frame buffer.
Pi4 now defaults to using DRM / KMS for display, which emulates the frame buffer. I don't believe that emulation supports 8bpp.
You can remove the "dtoverlay=vc4-fkms-v3d" line from /boot/config.txt to drop back to bcm2708_fb, but that will disable all 3D hardware (which is used by X for composition).
Return to “Graphics programming”
