paikuhan
Couldn't find matching render driver [LIBVLC][LIBSDL2][RPi3 B]
Sat Nov 09, 2019 3:29 pm
Hi, I am trying the simple libvlc demo with libsdl2 from https://wiki.videolan.org/LibVLC_SampleCode_SDL/ but I am having issues when running the compiled binary. I get a "Couldn't find matching render driver" error from SDL_GetError() after SDL_CreateRenderer(). here is the source:
// libSDL and libVLC sample code.
// License: [http://en.wikipedia.org/wiki/WTFPL WTFPL]
#include <stdio.h>
#include <stdint.h>
#include <math.h>
#include <stdlib.h>
#include <assert.h>
#include <SDL2/SDL.h>
#include <SDL2/SDL_mutex.h>
#include <vlc/vlc.h>
#define WIDTH 640
#define HEIGHT 480
#define VIDEOWIDTH 320
#define VIDEOHEIGHT 240
typedef struct context {
    SDL_Renderer *renderer;
    SDL_Texture *texture;
    SDL_mutex *mutex;
    int n;
} context;
// VLC prepares to render a video frame.
static void *lock(void *data, void **p_pixels) {
    struct context *c = (context *)data;
    int pitch;
    SDL_LockMutex(c->mutex);
    SDL_LockTexture(c->texture, NULL, p_pixels, &pitch);
    return NULL; // Picture identifier, not needed here.
// VLC just rendered a video frame.
static void unlock(void *data, void *id, void *const *p_pixels) {
    uint16_t *pixels = (uint16_t *)*p_pixels;
    // We can also render stuff.
    int x, y;
    for(y = 10; y < 40; y++) {
        for(x = 10; x < 40; x++) {
            if(x < 13 || y < 13 || x > 36 || y > 36) {
                pixels[y * VIDEOWIDTH + x] = 0xffff;
            } else {
                // RV16 = 5+6+5 pixels per color, BGR.
                pixels[y * VIDEOWIDTH + x] = 0x02ff;
    SDL_UnlockTexture(c->texture);
    SDL_UnlockMutex(c->mutex);
// VLC wants to display a video frame.
static void display(void *data, void *id) {
    SDL_Rect rect;
    rect.w = VIDEOWIDTH;
    rect.h = VIDEOHEIGHT;
    rect.x = (int)((1. + .5 * sin(0.03 * c->n)) * (WIDTH - VIDEOWIDTH) / 2);
    rect.y = (int)((1. + .5 * cos(0.03 * c->n)) * (HEIGHT - VIDEOHEIGHT) / 2);
    SDL_SetRenderDrawColor(c->renderer, 0, 80, 0, 255);
    SDL_RenderClear(c->renderer);
    SDL_RenderCopy(c->renderer, c->texture, NULL, &rect);
    SDL_RenderPresent(c->renderer);
static void quit(int c) {
    SDL_Quit();
    exit(c);
int main(int argc, char *argv[]) {
    libvlc_instance_t *libvlc;
    libvlc_media_t *m;
    libvlc_media_player_t *mp;
    char const *vlc_argv[] = {
        "--no-audio", // Don't play audio.
        "--no-xlib", // Don't use Xlib.
        // Apply a video filter.
        //"--video-filter", "sepia",
        //"--sepia-intensity=200"
    int vlc_argc = sizeof(vlc_argv) / sizeof(*vlc_argv);
    SDL_Event event;
    int done = 0, action = 0, pause = 0, n = 0;
    struct context context;
    if(argc < 2) {
        printf("Usage: %s <filename>\n", argv[0]);
        return EXIT_FAILURE;
    // Initialise libSDL.
    if(SDL_Init(SDL_INIT_VIDEO) < 0) {
        printf("Could not initialize SDL: %s.\n", SDL_GetError());
    // Create SDL graphics objects.
    SDL_Window * window = SDL_CreateWindow(
            "Fartplayer",
            SDL_WINDOWPOS_UNDEFINED,
            WIDTH, HEIGHT,
            SDL_WINDOW_SHOWN|SDL_WINDOW_RESIZABLE);
    if (!window) {
        fprintf(stderr, "Couldn't create window: %s\n", SDL_GetError());
        quit(3);
    context.renderer = SDL_CreateRenderer(window, -1, 0);
    if (!context.renderer) {
        fprintf(stderr, "Couldn't create renderer: %s\n", SDL_GetError());
        quit(4);
    context.texture = SDL_CreateTexture(
            context.renderer,
            SDL_PIXELFORMAT_BGR565, SDL_TEXTUREACCESS_STREAMING,
            VIDEOWIDTH, VIDEOHEIGHT);
    if (!context.texture) {
        fprintf(stderr, "Couldn't create texture: %s\n", SDL_GetError());
        quit(5);
    context.mutex = SDL_CreateMutex();
    // If you don't have this variable set you must have plugins directory
    // with the executable or libvlc_new() will not work!
    printf("VLC_PLUGIN_PATH=%s\n", getenv("VLC_PLUGIN_PATH"));
    // Initialise libVLC.
    libvlc = libvlc_new(vlc_argc, vlc_argv);
    if(NULL == libvlc) {
        printf("LibVLC initialization failure.\n");
    m = libvlc_media_new_path(libvlc, argv[1]);
    mp = libvlc_media_player_new_from_media(m);
    libvlc_media_release(m);
    libvlc_video_set_callbacks(mp, lock, unlock, display, &context);
    libvlc_video_set_format(mp, "RV16", VIDEOWIDTH, VIDEOHEIGHT, VIDEOWIDTH*2);
    libvlc_media_player_play(mp);
    // Main loop.
    while(!done) {
        action = 0;
        // Keys: enter (fullscreen), space (pause), escape (quit).
        while( SDL_PollEvent( &event )) {
            switch(event.type) {
                case SDL_QUIT:
                    done = 1;
                    break;
                case SDL_KEYDOWN:
                    action = event.key.keysym.sym;
                    break;
        switch(action) {
            case SDLK_ESCAPE:
            case SDLK_q:
                done = 1;
                break;
            case ' ':
                printf("Pause toggle.\n");
                pause = !pause;
                break;
        if(!pause) { context.n++; }
        SDL_Delay(1000/10);
    // Stop stream and clean up libVLC.
    libvlc_media_player_stop(mp);
    libvlc_media_player_release(mp);
    libvlc_release(libvlc);
    // Close window and clean up libSDL.
    SDL_DestroyMutex(context.mutex);
    SDL_DestroyRenderer(context.renderer);
    quit(0);
    return 0;
I've only done a few modification to the code:
  • replace "SDL.h" by <SDL2/SDL.h>
  • replace struct context{}; by typedef struct context{}context;
I don't know what the issue is but I am pretty sure it is SDL related because even a simple SDL example where I'm just clearing the screen doesn't work properly. As the picture below shows:
As you can see, instead of clearing the window the renderer of the "Hello World" SDL Window does nothing. And all we see it everything that is behind the SDL Window. I moved the SDL "Hello World" window before taking the screenshot. That's why things look like they are out of place.
Here is the code for the simple SDL Hello World app:
    SDL_Window *win = NULL;
    SDL_Renderer *renderer = NULL;
    int posX = 100, posY = 100, width = 640, height = 480;
    SDL_Init(SDL_INIT_VIDEO);
    win = SDL_CreateWindow("Hello World", posX, posY, width, height, 0);
    renderer = SDL_CreateRenderer(win, -1, SDL_RENDERER_ACCELERATED);
	SDL_SetRenderDrawColor(renderer, 255, 0, 0, 255);
    while (1) {
        SDL_Event e;
        if (SDL_PollEvent(&e)) {
            if (e.type == SDL_QUIT) {
                break;
        SDL_RenderClear(renderer);
        SDL_RenderPresent(renderer);
    SDL_DestroyRenderer(renderer);
    SDL_DestroyWindow(win);
    SDL_Quit();
    return 0;
Please note that the SDL Hello World app doesn't generate a "Couldn't find matching render driver" error. Although I would appreciate finding a solution for both the issue (my main concern is the libvlc one); solving the Hello World app might not necessarily solve the libvlc app.
Also note that I am running everything on the Kano OS (some kind of fork of the Raspbian OS by Kano.me ).
Thanks in advance!
Return to “Graphics programming”
