The target SDcard is a 16 GB card whereas the live card is 32 GB but the used size is only 12 GB, so it should fit on a 16GB card.
I attached the target SD-card to my RPi4 using an USB memory reader and started "Accessories/SD Card Copier".
In the From Device box I selected EB1QT (/dev/mmcblk0) and in the target box I selected Mass Storage Device (/dev/sda), it was the only allowed item.
Now I thought that I was done and could use the Start button, but it is not enabled!
Is this because the target card contains a Pi image already? It is an old OSMC media center image I no longer use.
Since SD Card Copier purportedly does not need the same or larger size card only as large as will fit the actual data I thought I could re-use my old card.
But it seems like I am out of luck here.
Is there any way to erase the existing target SD card so SD Card Copier can use it???
THis is what I see in a terminal:
sudo blkid
/dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="9F2D-0578" TYPE="vfat" PARTUUID="5e3da3da-01"
/dev/mmcblk0p2: LABEL="rootfs" UUID="efc2ea8b-042f-47f5-953e-577d8860de55" TYPE="ext4" PARTUUID="5e3da3da-02"
/dev/mmcblk0: PTUUID="5e3da3da" PTTYPE="dos"
/dev/sda1: UUID="E41A-EA0D" TYPE="vfat" PARTUUID="00095b1c-01"
/dev/sda2: UUID="bb3ea5f8-ef8b-4df3-9e6e-520f330875d8" TYPE="ext4" PARTUUID="00095b1c-02"
sudo lsblk -o UUID,NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL,MODEL
UUID NAME FSTYPE SIZE MOUNTPOINT LABEL MODEL
sda 14.9G Storage_Device
E41A-EA0D ├─sda1 vfat 243M
bb3ea5f8-ef8b-4df3-9e6e-520f330875d8 └─sda2 ext4 14.6G
mmcblk0 29.8G
9F2D-0578 ├─mmcblk0p1 vfat 256M /boot boot
efc2ea8b-042f-47f5-953e-577d8860de55 └─mmcblk0p2 ext4 29.6G / rootfs
