ho installato selinux-basics e selinux-policy-default su raspbian. In pratica quando do il comando sudo check-selinux-installation ottengo questo errore
getfilecon: getfilecon(/proc/1) failed
File "/usr/sbin/check-selinux-installation", line 33, in <module>
results += test.test()
File "/usr/share/selinux-basics/tests/24_fsckfix.py", line 24, in test
raise IOError("/etc/default/rcS not found, is this Debian?")
Posso risolvere in qualche modo? GRazie
