I would like a 14.4 but if that is lagy whatever would run better on a 4HawaiianPi wrote: ↑Thu Oct 31, 2019 12:54 amFor which version of Minecraft?
I ran a Java Edition 1.14.4 test server on a Raspberry Pi 4B 2GB for couple of months and was disappointed with the results. It was playable, but there were annoying lag spikes and rubber-banding. My 9-year-old broken Sony laptop works much better.
I've been meaning to try it again with a 64-bit OS and 4B4, but I haven't had the time.
On the other hand, I have a Java 1.12.2 SMP server that's been running since 2017 on a 3B (now a 3B+) which works well.
(SpigotMC with Oracle Java 8, Raspbian Lite, headless)
My test server was made when 32-bit Raspbian was the only OS and I could not get a 4GB model. It might work better with a 64-bit OS and Java on a 4GB Pi4, but like I said above, I just haven't had the time to try it (I do have a 4GB now).
So, the full RAM has been available via gentoo-on-rpi-64bit since v1.5.0 (shipped Aug 15th) (the current release is v1.5.1).HawaiianPi wrote: ↑Sat Nov 02, 2019 9:37 amIf not, then there's Sakaki's 64-bit Gentoo, but you'll have to check if the RAM limit bug was fixed. I'll play with this as time allows.
Thanks for the info, and all your work on Gentoo!sakaki wrote: ↑Mon Nov 04, 2019 12:20 amSo, the full RAM has been available via gentoo-on-rpi-64bit since v1.5.0 (shipped Aug 15th) (the current release is v1.5.1).
hth, sakaki
I am fairly new to the pi could you please create a step by step, that would be amazingHawaiianPi wrote: ↑Sat Nov 02, 2019 9:37 amMy test server was made when 32-bit Raspbian was the only OS and I could not get a 4GB model. It might work better with a 64-bit OS and Java on a 4GB Pi4, but like I said above, I just haven't had the time to try it (I do have a 4GB now).
There's a 64-bit kernel and multi-arch support in Raspbian that I just started playing with tonight. Not sure if it will do what we want. If not, then there's Sakaki's 64-bit Gentoo, but you'll have to check if the RAM limit bug was fixed. I'll play with this as time allows.
If you want to give this a try yourself, I suggest you use the SpigotMC server. It's much faster than the Mojang server (and more versatile). They have an easy to use build tool (BuildTools.jar), so it's not hard to get Spigot up and running.
