Bope
Thonny vs Terminal
Mon Oct 28, 2019 1:05 pm
I have a project with a Pi Zero that checks the status of a couple GPIO pins every 5 minutes. So most of the time the system is idle. Is there any benefit running the program from Thonny vs Terminal?
topguy
Re: Thonny vs Terminal
Mon Oct 28, 2019 1:08 pm
Quite the opposite I would think... most people dont run their programs from the development environment.
Bope
Mon Oct 28, 2019 6:57 pm
That is what I was wondering is if either environment had an advantage over the other for running the finished code.
jahboater
Mon Oct 28, 2019 7:22 pm
No. Running the IDE will use extra resources (extra memory mostly) to no purpose.
Furthermore its harder to run the program, you have to start thonny first.
