JakeQuinn
Get Reading from ADS1115
Fri Oct 25, 2019 12:57 am
Hello I am trying to compare the speed of how many data samples can i get from ADS1115 between python and C++. So far i have tested the python using Adafruits library. Now i am looking for a sample code in C++ to take a reading but i could not find a very basic one. I have seen that the wiringPi library has a ads1115.h, but i could not find documentation of a sample code.
salvato
Re: Get Reading from ADS1115
Fri Oct 25, 2019 9:36 am
I have written a class (it is written for a Qt program but not too difficult to modify) for the ADS1115.
give a look at:
https://github.com/salvato/TControllerR ... ds1115.cpp
and
https://github.com/salvato/TControllerR ... /ads1115.h
You can instantiate an ADS1115 object like this:
pADC = new ADS1115(QString("/dev/i2c-1"), 0x48);
and ... to read a value:
double newValue = pADC->ReadData();
Hope this help.
dsyleixa123
Fri Oct 25, 2019 12:49 pm
heya,
@salvato: thanks for your contributions!
2 questions:
what does newValue = pADC.ReadData() do?
And why is it double? actually it's a 16-bit ADC...?!
I actually expected functions like
int16_t  adc0, adc1, adc2, adc3;
  adc0 = pADC.readADC(0);
  adc1 = pADC.readADC(1);
  adc2 = pADC.readADC(2);
  adc3 = pADC.readADC(3);
dsyleixa123
Fri Oct 25, 2019 12:54 pm
I double the OP's question:
where are example source codes for the wiringPi ads1115.h lib? ("unofficially" forked at https://github.com/WiringPi/WiringPi/bl ... /ads1115.c)
LdB
Fri Oct 25, 2019 1:40 pm
I2C is pretty straight forward on the linux device API
run Raspi_Config and turn on the I2C, reboot and then you can access it via "/dev/i2c-1"
int fd = open("/dev/i2c-1", O_RDWR));
I just started from amaork's code and its pretty basic C/C++
https://github.com/amaork/libi2c/blob/master/src/i2c.c
If you have basic C/C++ ability and know the device address layout it shouldn't be hard.
dsyleixa123
Fri Oct 25, 2019 1:59 pm
and where are example source codes for the wiringPi ads1115.h lib?
LdB
Fri Oct 25, 2019 2:22 pm
There is no requirement for wiringPi done that way.
It comes down to do you know basic C/C++ coding.
If you are a novice and need wiringPi then probably drop Gordon a message on his site, I am not sure how often he calls thru here.
dsyleixa123
Fri Oct 25, 2019 3:10 pm
I do not want to hijack the OP's topic but I personally would prefer to know how to use the wiringPi ads1115.h lib
On Gordon's website I can find just examples about MCP and PCF ICs.
Fri Oct 25, 2019 4:28 pm
That won't work and I suspect he's given up with the forum.
http://wiringpi.com/wiringpi-deprecated/
LdB
Fri Oct 25, 2019 5:17 pm
Thanks for that Dougie and I sympathize some of Gordon's issues ... I baulked at telling them how to do it for exactly some of those reasons :-)
I was feeding into his problems by trying to send him more newbies.
To any moderate skill level programmer It's obvious what to do and how it works. But yeah problems with newbies and they abuse the situation (the old why should I read and learn when you know).
dsyleixa123
Sat Oct 26, 2019 8:07 am
The objective of "Wiring" was to make it easy for artists, designers, and beginners to work with electronics, by abstracting away the often complicated details of electronics so they can focus on their own objectives
https://arduinohistory.github.io/
http://people.interactionivrea.org/h.ba ... ow_res.pdf
So what is wrong about asking how to use the ads1115 lib of WiringPi? And as it already exists: about where to find example codes how to use it?
Sat Oct 26, 2019 8:53 am
So what is wrong about asking how to use the ads1115 lib of WringPi [sic]? And as it already exists: about where to find example codes how to use it?
Because it's now, effectively, unsupported and unsupportable.
If you use WiringPi, you're on your own. When it breaks you get the bugs to add to your collection.
#include <wiringPi.h>
#include <ads1115.h>
#define PINBASE 120
void main(int argc, char* argv[])
 ads1115Setup (PINBASE, 0x48);
 int analog1 = analogRead(2);
This code is 100% untested (I don't have the hardware), based on reading the instructions at http://wiringpi.com/extensions/
dsyleixa123
Sat Oct 26, 2019 10:22 am
perhaps my ads1115 IC is meanwhile damaged, but I always get readings =0, at either ads1115 ADC pin:
// code still not working yet, deleted not to confuse people...
PS, edit:
wiringPi is also forked on github, so if one once had a working example then one might submit a pull request! 8-)
Sat Oct 26, 2019 11:07 am
It's never been on Github, so that's clearly been done by someone who has helped to contribute to the demise of wiringPi. It is bound to be an old version that won't be supported by the person who stuffed it on Github and likely won't work on an RPi4.
Choose any other library or write your own code using linux/i2c-dev.h and /dev/i2c0-1.
dsyleixa123
Sat Oct 26, 2019 1:30 pm
[offtopic]
it's been forked by a 3rd party, yes, but quite up-to-date though.
OTOH, all the linux/i2c-dev.h and /dev/i2c0-1 stuff and even pigpio is far to complicated for non-professionals.
So IMO WiringPi should be updated at github further on though - unless someone once creates a new "Wiring" based, Arduino-like C++ GPIO lib, but that's another topic
[/offtopic]
anyway, perhaps someone else could provide or link to a tested, working ads1115-wiringPi example.
dsyleixa123
Sat Oct 26, 2019 1:34 pm
PS,
why is in your code
and not
analog1 = analogRead(1);
Sat Oct 26, 2019 1:50 pm
PS,
why is in your code
and not
Because I was testing that I'd read Gordon's code correctly. I don't have the hardware so had to read ads1115.h and ads1115.c to see how it worked (my example does compile OK).
dsyleixa123
Sat Oct 26, 2019 1:53 pm
yes, my example in which I reworked your example also compiles fine, but nonetheless, as already stated, I just get repetitive readings = 0 at either ADS1115 ADC pin though.
dsyleixa123
Sat Oct 26, 2019 1:57 pm
GOT IT!
it must be
analog1 = analogRead(PINBASE+1); // connected to ads1115 A1
dsyleixa123
Sat Oct 26, 2019 2:00 pm
so this is the tested, functioning ads1115 code using wiringPi:
// ads1115 example wiringPi
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <inttypes.h>
#include <stdbool.h>
#include <wiringPiI2C.h>
#define  PINBASE  120    // choose  PINBASE  value arbitrarily
#define  ADS_ADDR 0x48
int main() {
   int analog1;
   int ioerr = wiringPiSetupGpio();
     if( ioerr == -1 ) return 1;
   ads1115Setup (PINBASE, ADS_ADDR);
   while(true) {
       printf("analog1 = %d \n", analog1);
       delay(250);
  return 0;
thanks a lot for your contributions! 8-)
aminka
Tue Jun 30, 2020 6:53 pm
Could some one please write a simple example for ads1115.h (wiringPi) to read measures from 4 sensors in a while loop with set a sample rate and other configs ?
Thank you very much .
dsyleixa123
Wed Jul 01, 2020 7:26 am
Actually it's basically my code from above!
So for all 4 ADS1115 sensors:
// my common #includes
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
int main() {
   int analog0,analog1,analog2,analog3;
   while(true) {
        analog0 = analogRead(PINBASE+0);      // connected to ads1115 A0
          printf("analog0 = %d \n", analog0);
        analog2 = analogRead(PINBASE+2);    // connected to ads1115 A2
          printf("analog2 = %d \n", analog2);
        analog3 = analogRead(PINBASE+3);    // connected to ads1115 A3
          printf("analog3 = %d \n\n", analog3);
       delay(250);  // sample rate 250ms
  return 0;
aminka
Thu Jul 02, 2020 4:53 pm
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
int main() {
   while(true) {
  return 0;
Thank you very much bro,did you test above code ? what about sample rate and gain configuring and how to use ALRT/READY pin ? And why we start PIN-BASE at 120 ?
Other question is how to purchase or order onboard memory raspberry pi for save our code privet ?
Very very thanks .
dsyleixa123
Thu Jul 02, 2020 6:34 pm
start pin 120 is arbitrary, wiringPi is pin-based and needs just a unique start pin.
Of course I tested the code, it works like a charm and even identical to the console program above when I use it in qt5.
About the rest of your questions I cannot give a statement, because I won't ever need to use it.
aminka
Fri Jul 03, 2020 12:12 pm
Ok thanks, but how to configure sample rate ? And for this code (your code) what is the sample rate? 860 sps ?
Return to “C/C++”
