UNeverNo
eth0 not initialized properly on startup/after reboot
Sat Oct 12, 2019 8:50 pm
After applying latest updates it seems that my raspberry 2 B 1.1 can't initalize the ethernet adapter properly, in fact there are only a couple of times when it doesn't fail on startup.
When I do a reboot, it almost always fails.
I also get some undervolting-messages although I'm just idling in terminal (I didn't observe this before).
Power supply #1: 5,23-5,26V @ 0,23A
Power supply #2: 5,13V @ 0,23A
Power supply #3: 5,07V @ 0,23A
OS: buster
Kernel: 4.19.75-v7+
B.Goode
Re: eth0 not initialized properly on startup/after reboot
Sun Oct 13, 2019 7:20 am
Welcome to the Raspberry Pi forums.
OS: buster
Kernel: 4.19.75-v7+
Your power supplies look under-specified.
See the tables published by Raspberry Pi here: https://www.raspberrypi.org/documentati ... /#pi-power
Product Recommended PSU current capacity Maximum total USB peripheral current draw Typical bare-board active current consumption
Raspberry Pi 2 Model B 1.8A 600mA/1.2A (switchable) 350mA
Return to “Raspbian”
