tizian
Pi4 dual screen: window span over both screens by cmdline?
Sat Oct 12, 2019 8:15 pm
anyone an idea? thanks in advance!
My question:
I try to open a window with cmdline which is fullscreen over both screens. In my case a chromium browser window.
My setting:
I use a Raspi 4 B and have connected two identical 19" Displays on the HDMI ports. The newest version of Raspian is installed. Monitor detection works fine direct from startup.
The following line is opening a fullscreen window on one display. unfortunately I found no option to have the window over both screens.
chromium-browser --incognito --kiosk http://google.com
dakky_tz
Re: Pi4 dual screen: window span over both screens by cmdline?
Mon Oct 21, 2019 9:07 pm
I am interested if there is any possibility to have a window maximized over two displays with Raspberry Pi4 and Raspbian OS. I am trying to get Citrix to detect and use both displays during a session and since I cannot maximize over both screens the session wont work in dual display mode.
Anyone have any idea how to resolve this?
HermannSW
Tue Jan 14, 2020 8:19 pm
I assume you tried from console and not X11.
There is only one framebuffer (/dev/fb0) when both HDMI displays are connected.
And when booting into console mode I see the same console output on both.
So what you want is not possible in console mode, you need X11.
I switched to boot into X11, and here a window can definitely span over two displays.
The right terminal shows only minimally on right side of 1360x768 HDMI-0.
And only minimally on left side of 1024x768 HDMI-1.
Most of the terminal is "between" both (top left coordinate of HDMI-0 is (0,0), of HDMI-1 is (1920,0)].
$ cat ~/.xsessionrc
xrandr --output HDMI-1 --mode 1360x768
xrandr --output HDMI-2 --mode 1024x768
Taking screenshot with "scrot" captures 1920+1024=2944 × 768 image:
P.S:
Here the two HDMI displays span a 3472x2200 X11 root window.
xlock started with "-geometry 3455x2150+5+5" nearly fills all of that, see screenshot.
Details here:
https://www.raspberrypi.org/forums/view ... 8&t=261980
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/github_repo_i420toh264
aBUGSworstnightmare
Wed Jan 15, 2020 5:11 am
$ cat ~/.xsessionrc
P.S:
Details here:
Hermann, if your desktop looks like this then there is something wrong! Are you using fkms driver or legacy driver (configured for dual screen)
HermannSW
Wed Jan 15, 2020 2:24 pm
What is wrong?
The background image is tiled over the big X11 root window.
All works as expected, details in the other thread.
This is setting in /boot/config.txt:
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
aBUGSworstnightmare
Wed Jan 15, 2020 7:12 pm
What is wrong?
it shouldn't be tiled like this. And why is it 1920+1024 if you set mode to 1360+1024?
HermannSW
Wed Jan 15, 2020 7:28 pm
What is wrong?
Because the background image is 1920x... and Raspian decided to place HDMI-2 right to background image initially.
Position of HDMI-[12] can be changed easily with "Preferences -> Screen Configuration" tool.
I increased the X11 root window size using that tool (up to 5000x5000).
You can see HDMI-1 top left and HDMI-2 bottom right, both in tool and root window snapshot.
https://www.raspberrypi.org/forums/view ... 0#p1595356
