benyrey
.py program run many times, not anymore. Please
Sat Oct 12, 2019 3:34 pm
I run my .py program many times, it always worked.
But now that I have a new internet service provider with a different router
(which I port forwarded) the same program does NOT run. My program is a web
server it uses this line:
return render_template('main.html', **templateData)
I always get the following error:
“TemplateNotFound: main.html”.
BTW, I am using a new Raspberrypi 3 B+. I do not believe
that it is the problem.
Please help me. Thanks
Beny
neilgl
Re: .py program run many times, not anymore. Please
Sat Oct 12, 2019 4:42 pm
In your new pi3 setup, using flask, have you created a folder with name “templates” in the same directory where the python file is located and put your main.html file in that templates folder?
benyrey
Sat Oct 12, 2019 5:07 pm
A Templates folder was already created in the new RPi. It came with it. I just put there the same main.html
file that I used before.
Thanks a lot.
Beny
scotty101
Sat Oct 12, 2019 6:56 pm
Templates and templates are not the same thing. Once has an upper case first letter.
It has to be a lower case t.
In your Pi directory create a new folder, place your .py file inside there and create a new templates folder there too and place the .HTML file inside that.
benyrey
Sat Oct 12, 2019 10:10 pm
You are right... thanks a lot ... i don't know what to say else. Sorry about it.
In my new RPi 3 B+ I renamed the folder Templates as templates. Following your
input, the file main.html was setting in. It just works ... period.
But I am not happy with Raspberrypi 3 B+. My program worked perfect for one year using the
former RPi 3 B+ with the folder Template (with T) and the main.html file in it.
I am just confused. Hey Man ... thanks a lot. You have a good week end.
I will have some beers now.
My respects
Beny
