Sulforaphane
Latest update made my RasPi4 stop working.
Sat Oct 12, 2019 3:23 pm
Hello.
I just updated my Raspberry Pi 4 as I always do, and suddenly it stopped at:
Unpacking raspberrypi-kernel-headers (1.20190925+1-1) over (1.20190819-1)
The connection went, no SSH and no screen connection.
I then tried rebooting and now it gives me three green LED flashes, and pauses and repeats itself.
I'm assuming some important system files got corrupted. The question is, can I fix this or is the only solution to reformat the SSD-card?
Thanks in advance
Re: Latest update made my RasPi4 stop working.
Sat Oct 12, 2019 3:54 pm
Get a copy of plain Raspbian Buster Lite and write that to a new SDCard
Boot that, insert your broken system SDCard in a USB reader, mount that in your RPi
From a command line run the following commands.
sudo fdisk -l /dev/sda to tell us whether it's plain Raspbian or NOOBS
sudo -s
to open a root shell (means you don't have to prefix everything with sudo).
if plain Raspbian
umount /dev/sda1
umount /dev/sda2
if NOOBS
umount /dev/sda5
umount /dev/sda6
Don't worry if those commands fail because the filesystem isn't mounted.
if plain Raspbian
mount /dev/sda2 /mnt
mount /dev/sda1 /mnt/boot
if NOOBS
mount /dev/sda6 /mnt
mount /dev/sda5 /mnt/boot
mount -o bind /dev /mnt/dev
mount -o bind /sys /mnt/sys
mount -t proc /proc /mnt/proc
We can now run a chroot (note the trailing full stop).
chroot .
In there run
apt update
apt dist-upgrade -y
to repair the broken system
Then exit the chroot and poweroff
exit
poweroff
Swap the SDCards back and boot normally.
I'll do your homework for you for a suitable fee.
Sulforaphane
Sat Oct 12, 2019 6:21 pm
sudo -s
if plain Raspbian
umount /dev/sda1
umount /dev/sda2
if NOOBS
umount /dev/sda5
umount /dev/sda6
if plain Raspbian
if NOOBS
chroot .
In there run
apt update
apt dist-upgrade -y
exit
poweroff
Wow thanks, but this is what it says when i run the command "chroot ." - chroot: failed to run command ‘/bin/bash’: No such file or directory
Sat Oct 12, 2019 7:00 pm
Oh dear. Your root filesystem has been destroyed - that's probably not salvageable.
You may want to test that your SDCard is not a fake.
Sulforaphane
Sat Oct 12, 2019 7:07 pm
I got it working by changing chroot from "chroot ." to "chroot /mnt/" and booting the Pi again.
However, while it is still working, everytime i run the sudo apt upgrade from the Pi itself it shows this in the terminal and just doesn't move:
Preparing to unpack .../raspberrypi-kernel-headers_1.20190925+1-1_armhf.deb ...
Unpacking raspberrypi-kernel-headers (1.20190925+1-1) over (1.20190819-1) ...
Progress: [ 11%] [################.......................................................................................................................................]
I have attached an image showing it.
Sulforaphane
Sat Oct 12, 2019 7:15 pm
No no, I got it working. I just had to change
chroot .
to
chroot /mnt/
and following the rest of your steps.
