wjmnelis
[Solved] With overlay of root, swap does not work
Fri Oct 11, 2019 5:40 pm
Swap does not work if an overlay over the root file system is defined.
In order to isolate the changes when compiling and installing a large program, and to extract the (compiled and linked) files needed to install that program on another RPi, an overlay of the root file system was defined. A 32 [GiB] SD card is used to install buster, and after configuration of Raspbian on an RPi, the SD card is modified using gparted. The large partition is halved and another partition (of about the same size) is defined. The RPi starts with this new partitioning of the SD card. The additional partition is mounted on /mnt. A modified version of script overlayRoot.sh (see http://wiki.psuter.ch/doku.php?id=solve ... _partition) is used. The modification is to use the additional partition in stead of tempfs file system(s).
It works, except for swap. In the 'upper dir', file /var/swap has been created with the configured size, but examination of /proc/meminfo shows that there is no swap space available. Various ways of stopping and starting, disabling and enabling dphys-swapfile all result in error message:
swapon: /var/swap: swapon failed: Invalid argument.
The status of the file systems is:
pi@rpi3r:~ $ lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk0     179:0    0 29,7G  0 disk
├─mmcblk0p1 179:1    0  256M  0 part /boot
├─mmcblk0p2 179:2    0 14,6G  0 part /ro
└─mmcblk0p3 179:3    0 14,9G  0 part /mnt
pi@rpi3r:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p2   15G  9,2G  4,6G  67% /ro
overlayfs-root   15G  2,1G   12G  15% /
devtmpfs        459M     0  459M   0% /dev
tmpfs           464M     0  464M   0% /dev/shm
tmpfs           464M  6,4M  457M   2% /run
tmpfs           5,0M  4,0K  5,0M   1% /run/lock
tmpfs           464M     0  464M   0% /sys/fs/cgroup
tmpfs            16M  4,0K   16M   1% /tmp
tmpfs           1,0M   32K  992K   4% /overlay/xymon
tmpfs           1,0M  4,0K 1020K   1% /var/lib/xymon/tmp
/dev/mmcblk0p3   15G  2,1G   12G  15% /mnt
/dev/mmcblk0p1  253M   52M  201M  21% /boot
overlayfs       1,0M   32K  992K   4% /var/lib/xymon/www
tmpfs            93M     0   93M   0% /run/user/1000
pi@rpi3r:~ $cat /proc/meminfo | fgrep Swap
SwapCached:            0 kB
SwapTotal:             0 kB
SwapFree:              0 kB
pi@rpi3r:~ $
What is needed to use swap space on the new root file system?
wjmnelis
Re: With overlay of root, swap does not work
Tue Oct 22, 2019 2:08 pm
Well, to answer my question at least partially: use a swap partition in stead of a swap file.
I did not succeed in getting swapping to a swap file to work. The swap file, /var/swap, is created but is not used. On a Linux laptop, the overlay partition is resized to free up 2 [GiB]. In this space, a swap partition is defined. The swap file definition is then entered in the initial root file system in file /etc/fstab. The entries with respect to the SD card are:
PARTUUID=5e3da3da-01	/boot		vfat	defaults	0	2
PARTUUID=5e3da3da-02	/		ext4	defaults,noatime 0	1
PARTUUID=5e3da3da-03	/mnt		ext4	defaults,noatime 0	1
PARTUUID=5e3da3da-04	none		swap	defaults	0	0
Then on the RPi 3B, the swap partition is activated:
sudo mkswap /dev/mmcblk0p4
sudo swapon /dev/mmcblk0p4
After a reboot, swap is active and being used. However, file /var/swap is still being generated although it is not used.
The current SD card layout and the file systems are:
pi@rpi3r:~ $ lsblk
├─mmcblk0p3 179:3    0 12,9G  0 part /mnt
└─mmcblk0p4 179:4    0    2G  0 part [SWAP]
pi@rpi3r:~ $ df -h
/dev/mmcblk0p2   15G  7,2G  6,6G  53% /ro
overlayfs-root   13G  313M   12G   3% /
tmpfs           464M   13M  451M   3% /run
tmpfs           1,0M  200K  824K  20% /var/lib/xymon/tmp
tmpfs           1,0M   52K  972K   6% /overlay/xymon
/dev/mmcblk0p3   13G  313M   12G   3% /mnt
overlayfs       1,0M   52K  972K   6% /var/lib/xymon/www
pi@rpi3r:~ $
epoch1970
Tue Oct 22, 2019 3:32 pm
FYI, I think there is now a new option in raspi-config to configure a rootfs overlay filesystem.
Never used it, no idea how it performs.
wjmnelis
Fri Oct 25, 2019 11:35 am
Thanks for the pointer, I did not know of this new feature in raspi-config.
However, examining the source code of raspi-config revealed that the upper file system is always a tmpfs, which is created by raspi-config. The upper file system cannot be specified and therefore this function is not a solution for my use case.
Moreover, there is no mention of swap in the script. (Strange as moving '/', and thus also '/var/swap' to tmpfs does seem usefull.) Thus raspi-config cannot serve as a source of inspiration to handle the swap-problem.
(I thought I had already posted a reply a few days ago, but when checking this thread it was not there. Above is the second attempt to post this reply.)
Return to “Advanced users”
