I recieved my raspberry Pi a few days ago and have been trying to set it up ever since.
At first everything was looking great, I bought a new sd-card from adata and installed raspbian wheezy.
After connecting the lan cable, the first problems started to arise. It would crash suddenly at random moments presenting me with nothing but a blank screen.
I had been using a usb power pack, and it turned out that with the ethernet cable, hdmi, keyboard and mouse the supply voltage dropped below 4.3 volts at times. The powerpack is rated at 2.1A so this was a little disappointing. I then switched to a powered usb hub with a 2A adapter, but this also caused voltage drops and crashes. I decided to completely overkill it and feed the usb hub with a ATX psu.
This thing is rated 20A at the 5v rail. Imho this should be enough, but voltage levels still drop below 4.8v
It is my understanding that the raspberry only operates at a narrow band of supply voltages, and anything below 4.8v will cause crashes, and anything above 5.1v will cause overheating.
I think its a miracle anyone got the thing working right with Phone chargers and the like. O_o
My htc Phone charger is rated at 1a and it outputs somewhere around 4.1-4.3 volts with my raspberry connected.
Why does my raspberry crash on a 20 amp power supply? could the usb hub be causing problems for me?
