Fri Oct 11, 2019 3:14 am
The most I can find is a dual outlet USB charger that puts out 2.4A from each USB port for a total of 4.8A. Which happens to be what I am using to run just the Pi 4 for the last couple of days, using both outlets into a single USB female socket via a Y-cable. (USB splitter cable)
The think in the picture with the blue light and 'Laser' written on it, and 2 x black leads into the white lead, is powering the Pi 4. the other stray USB cable on the power board is for something else.
I haven't seen a USB charger with a bigger output amperage than that so far.
There's a good chance one of these 'might' power a Pi 3 or 3B+ from each USB socket, but I think it would not power a Pi 4 from one USB socket.
- laser-adapter.jpg (9.77 KiB) Viewed 274 times
Remember, nobody is listening to you
until you fart ...
