NPDedyukhin
Writing the result to the list and to a text file.
Thu Oct 10, 2019 3:59 pm
Good afternoon!
There is such a script:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import os
myCmd = 'sudo iwlist wlan0 scan | grep "ESSID"'
os.system (myCmd)
After executing it, I see the result in the console:
ESSID:"Dedyu"
ESSID:"ROSTELECOM_7F98C"
ESSID:"TP-LINK_9_19"
ESSID:"ROSTELECOM_A0439"
ESSID:"ROSTELECOM_7ED66"
ESSID:"KV-14"
ESSID:"Keenetic_31"
ESSID:"Keenetic-8782"
ESSID:"TP-LINK_DC80"
ESSID:"HomeNet994"
ESSID:"Devlor"
ESSID:"Krat0s's wifi_2"
ESSID:"RTK-104035"
ESSID:"Zinchenko"
ESSID:"Dzirt"
ESSID:"Black Lion"
Please help me edit my script so that it line-by-line saves all this data to a text file.
I tried it this way, but it failed:
import os
networks = [os.system (myCmd)]
with open(r"/home/pi/Desktop/pi_cam/networks.txt", "w") as file:
    for  line in networks:
        file.write(str(line))
After executing such a script, the text file contains only "0" :|
Respectfully,
Nikita Dedyukhin
Re: Writing the result to the list and to a text file.
Thu Oct 10, 2019 4:06 pm
Change that line to
myCmd = 'sudo iwlist wlan0 scan | grep "ESSID" > /home/pi/Desktop/pi_cam/networks.txt'
then delete the rest of the program after the call to os.system().
The whole python piece becomes redundant. You may as well run sudo iwlist wlan0 scan | grep "ESSID" > /home/pi/Desktop/pi_cam/networks.txt in the command line shell, or as a bash shell script.
NPDedyukhin
Thu Oct 10, 2019 4:37 pm
Change that line to
Thanks you!
Respectfully,
Nikita Dedyukhin
hippy
Thu Oct 10, 2019 5:00 pm
A more Pythonic way to do it which allows processing of the lines as they are output -
import os
lines = os.popen('sudo iwlist wlan0 scan | grep "ESSID"').read().strip().split("\n")
with open("/home/pi/Desktop/pi_cam/networks.txt", "w") as f:
  for line in lines:
    f.write(line.strip()+"\n")
NPDedyukhin
Fri Oct 11, 2019 4:58 am
import os
  for line in lines:
Thank you very much!
Respectfully,
Nikita Dedyukhin
blimpyway
Sat Oct 12, 2019 7:40 pm
...or the least pythonic
#!/bin/bash
Return to “Python”
