To enable support for the RTC in Raspbian Wheezy' (2012-10-28 or later),
the following lines need to be added to /etc/rc.local above the exit0 line:
modprobe i2c-bcm2708
echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device
modprobe rtc-ds1307
hwclock -s
These instructions should work with any DS1307 or DS1338 Real Time Clocks, it has been tested with CJE Micro's/4D RTC http://www.cjemicros.co.uk/micros/indiv ... eClock-RTC
If anyone has any problems or suggestions re this please post here.
Chris Evans (CJE Micros's & 4D)
Re: Instructions to Configure DS1307 or DS1338 RTC
It's important to note that if you are using a Rev2 RasPi then you need to replace i2c-0 with i2c-1.arm2 wrote:To enable support for the RTC in Raspbian Wheezy' (2012-10-28 or later),
modprobe rtc-ds1307
hwclock -s
Paul
UK Supplier of 1-Wire components, kits and modules:
http://www.sheepwalkelectronics.co.uk/
Thanks for that info:
Not elegant but would
echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-1/new_device
modprobe rtc-ds1307
hwclock -s
work?
I'm used to RISC OS where you could have a utility that sets a system variable and then you can have conditional execution in the boot script like:
IF Rev$Pi=0 THEN echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device
IF Rev$Pi>0 THEN echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-1/new_device
modprobe rtc-ds1307
hwclock -s
modprobe rtc-ds1307
hwclock -s
work?
modprobe rtc-ds1307
hwclock -s
On Fedora ARM on Pi...
# echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-1/new_device
-bash: echo: write error: Invalid argument
Does not seem to work on my Model 2. However, I am still able to set and query the RTC clock. So new_device is set somehow.
Thinking more about this... I pulled my older Model 2 with only 256 MB out of obsolete drawer... and tried the same steps, making sure the Fedora ARM image was pristine... since my work bench Model 2 Fedora image has I2C, SPI, and more goodies support already loaded. Long story short the steps as document work, I don't get the invalid write error.
# echo $?
0
# echo $?
0
Just an update... Fedora 18 ARM... support ds1307 has been dropped. This is a real disappointment, because I have i2c ds1307 add-on boards for a few of my Pi devices, and now it appears I have to remain on Fedora 17, or change distributions. Best I can determine, Fedora ARM team decided that since ds1307 based RTCs are not a consistent feature of ARM devices, there was no need to continue support because it establishes what they called an inconsistent platform? Whatever that means.
Reference...
https://lists.fedoraproject.org/pipermail/arm/2013-January/005066.html
Reference...
Is anyone aware of any updates to this issue relating to DS1307 support in Fedora 18 (Pidora)?
It appears only the command:
echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-1/new_devices
is failing, but that other commands are working okay, such as:
hwclock -r ... to "read" contents of RTC
hwclock -s ... to "set" time/date from contents of RTC
hwclock -w ... to "write" current date into RTC
This presumes performing a "modprobe rtc-ds1307".
Is the "echo ds1307 0x68" command needed for anything?
I cannot run inside bash script because it gives me error:
echo "ds1307 0x68" > /sys/class/i2c-adapter/i2c-1/new_device
. Why?!line 3: echo: write error: Invalid argument
What model pi do you have?MarkoSiroki wrote:I cannot runinside bash script because it gives me error:Code: Select all
Which OS and OS version?
Which kernel version?
Try
echo "ds1307 0x68" | sudo tee /sys/class/i2c-adapter/i2c-1/new_device
I'm having the same problem.
Details:
Raspberry Pi Model B
Linux raspberrypi 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l GNU/Linux
Thank in advance!
Julia
Details:
Thank in advance!
Julia
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Take a look at /boot/overlays/README if dtoverlay=i2c-rtc is documented in there then you've got kernel support.
If it's not there run sudo rpi-update (to get to 3.18.12).
Addto /boot/config.txt then reboot and your RTC will be running with nothing needed. No strange echo commands are needed.
Add
dtoverlay=i2c-rtc,ds1307
Thank you,
I do indeed have the following in the /boot/overlays/README
File: ds1307-rtc-overlay.dtb
Info: Configures the DS1307 Real Time Clock
Load: dtoverlay=ds1307-rtc
Params: <none>
I am able to query and set the hwclock. However, for some reason the hwclock is being set by the system clock on bootup (instead of the other way around).
It's behaviour is the following:
I set the system time to ‘Fri May 1 2015, 7:10AM’.
I set the hwclock time to ‘Fri May 1 2015, 7:10AM’.
I wait five minutes.
Times have moved forward 5 minutes appropriately (‘Fri May 1 2015, 7:15AM’).
I shut the RPi down, wait 5 minutes.
Boot up, and both are set to ‘Fri May 1 2015, 7:15AM’.
Ideally, both would show ‘Fri May 1 2015, 7:20AM’.
Do you have any idea what startup script could be causing this?
Thank you,
Julia
Params: <none>
Thank you,
Julia
- DougieLawson
You need to get rid of fake-hwclock and ensure that hwclock gets run at shutdown and again at restart.
I am having the same problem.
When I do it shows my DS3231 as 68 . But when I do the command I get the "permission denied" message.
I have a model B+
I am quite new here, so please answer in laymen terms
When I do
sudo i2cdetect -y 1
pi@raspberrypi ~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
oech ds1307 0x68 >> /sys/class/i2c-adapter/i2c-1/new_device
echo ds3231 0x68 > /sys/class/i2c-adapter/i2c-1/new_device
bash: /sys/class/i2c-adapter/i2c-1/new_device: Permission denied
Thanks for this. I addedDougieLawson wrote:Take a look at /boot/overlays/README if dtoverlay=i2c-rtc is documented in there then you've got kernel support.
Addto /boot/config.txt then reboot and your RTC will be running with nothing needed. No strange echo commands are needed.Code: Select all
sudo hwclock -r
