NPDedyukhin
Writing to a text file in a specific line.
Wed Oct 09, 2019 4:37 pm
Good afternoon! ;)
I have a variable, it takes a certain value. I know that the value of this variable should always be on the third line in my text file. Always the third line.
It doesn’t matter what is now contained in the third line.
When a variable changes its value, you just need to open the file, delete everything from the third line and write a new value there.
How to do it? :|
Respectfully,
Nikita Dedyukhin
B.Goode
Re: Writing to a text file in a specific line.
Wed Oct 09, 2019 4:44 pm
Good afternoon! ;)
How to do it? :|
Can you clarify your purpose posting these questions please?
Are they genuinely problems that you need help with?
Or are they educational Public Service 'brainteasers' to which you will publish the solution in a few hours time?
[In the specification for the current puzzle you don't mandate anything about the first two lines of the file - do they have to be maintained in an unmodified state?]
Andyroo
Wed Oct 09, 2019 5:02 pm
I would also ask how is the line terminated?
CR/LF or CR is more difficult than LF
Binary in the text is even more of a pain
Are you converting numbers to go into the third line?
Does my other leg ring when you pull it?
Need Pi spray - these things are breeding in my house...
gordon77
Wed Oct 09, 2019 5:24 pm
try this...
#!/usr/bin/env python3
# open existing file
Lines = []
with open("test.txt","r") as f:
    line = f.readline()
    while line:
        Lines.append(line.strip())
        line = f.readline()
# change the 3rd line
var = 1.234
Lines[2] = str(var)
# write the file again
with open('test.txt', 'w') as f:
   for item in Lines:
       f.write("%s\n" % item)
PhatFil
Wed Oct 09, 2019 6:39 pm
the head command with can deliver the top 2 lines from the file into a new replacement,
you can then echo Value >> into the 3rd line, and as long as you know how many lines are in the file you can tail the remainder into the replacement file..
if 10 lines in your file??
head -2 > yournewfile.txt
echo "newline3" >> yournewfile.txt
tail -7 >> yournewfile.txt
https://www.tecmint.com/view-contents-of-file-in-linux/
use the wc 'wordcount' command to extract the number of lines in a file tho i cant recall the switch/flag s? required but there is some homework for you ;), but it shouldnt add more than a few lines..
NPDedyukhin
Wed Oct 09, 2019 7:13 pm
try this...
Lines = []
    line = f.readline()
    while line:
        line = f.readline()
var = 1.234
Lines[2] = str(var)
   for item in Lines:
Yes, it did. I did about the same.
Here is part of my code:
file_1 = open("/home/pi/Desktop/pi_cam/settings.txt", "r")
lines = file_1.readlines()
lines[2] = str(a) + '\n'
file_1.close()
file_2 = open("/home/pi/Desktop/pi_cam/settings.txt", "w")
file_2.writelines(lines)
file_2.close()
Respectfully,
Nikita Dedyukhin
NPDedyukhin
Wed Oct 09, 2019 7:16 pm
Good afternoon! ;)
How to do it? :|
The goal is to place data “on the shelves”.
Certain information must correspond to each line: for example, in the first line we will store information about the type of connection, in the second line information about the network name and so on.
The data request can be repeated, and in order to avoid duplication of data, they should be stored in a strictly defined place for them.
Respectfully,
Nikita Dedyukhin
Andyroo
Wed Oct 09, 2019 8:13 pm
Look at SQL (MariaDB or SQLite) rather than flat files.
If you really want to use flat files then look at ini file processing with the configparser module or json processing
Heck, you could even look at pickle and store the data in a Python dictionary.
I think you may do best to learn a little more about the basics of the language via YouTube or a formal course rather than firing off random limited scope questions as your resultant code could well be an unsupportable mess.
blimpyway
Thu Oct 10, 2019 7:30 am
Only if these files and their formatting are already generated/used by applications out of your control makes sense to use a cryptic, specialised flat file format for structured data.
Otherwise I would take Andyroo's advice, use a standard one like json.
gordon77
Thu Oct 10, 2019 7:45 am
file_1.close()
file_2.close()
Good you got it working for what you require. As others have said there are many other ways you could use but if it meets your requirements at the moment that's fine.
jerrm
Thu Oct 10, 2019 1:53 pm
sed -i '3s/.*/newvalue/' file
Return to “Python”
