wadalahari
Xorg and video driver for RPi4
Tue Oct 08, 2019 8:18 pm
what is the video module for RPi 4?
I am trying to configure Xorg using
Xorg :0 -configure
but the configuration fails.
I installed
 xf86-video-fbdev
 xf86-video-fbturbo-git
the 1st works for RPi2 installation (on a RPi3 board).
Any ideas? The command
$ lspci | grep VGA
is not helpful.
topguy
Re: Xorg and video driver for RPi4
Wed Oct 09, 2019 1:53 pm
Which operating system are your running ?
Why do you want to reconfigure it ?
On Raspbian Buste I belive you dont have an "xorg.conf", its all autodetected.
PeterO
Wed Oct 09, 2019 4:12 pm
Note this is in the Arch" forum, so references to what happens in Buster aren't going to be helpful....
PeterO
PS: I made a similar "Why do you want to do this" post yesterday but deleted it when I realise which forum it was in,
topguy
Wed Oct 09, 2019 4:47 pm
ah... yes I forget to check sub-forum quite often to be honest.
raspphibian
Mon Nov 25, 2019 2:57 am
Thanks, this helped me get xorg and with that gnome working.
I had to install xf86-video-fbdev to get xorg working, and to get gdm working I had to disable wayland and set xorg as the backend for it
I hope you in the meantime you managed to get yours started as well. Otherwise let me know, I might be able to help you.
Return to “Arch”
