clunkk
Problem flashing SD card with marshmellow
Sun Oct 06, 2019 4:32 am
I am having a bizarre problem. Whenever I try and flash marshmellow to an sd card it splits my sd card into four drives. I've tried using etcher and win32discimager and two computers but I get the same problem. I'm so confused. I don't know where else to post for advice and I really need to get this pi working. I was able to get lakka working with it for retropie. I've tried different sd cards and readers and power sources. I just get the rainbow screen when i try to boot..
It changes my sd card to 'boot' and it is read in F G H I drives. I don't know why its splitting the partition drive in this way??
Help!!
pcmanbob
Re: Problem flashing SD card with marshmellow
Sun Oct 06, 2019 2:31 pm
Hi.
It looks like you are trying to install Android on your SD card , as there is no official android OS,
I suggest you look to were ever you download the image from for support.
But in general if your SD card is being split in to a number of drives the it must be the way the image is setup to prepare the SD card.
Raspbian for example creates 2 drives a fat32 and a Linux drive on the SD card.
Sun Oct 06, 2019 3:44 pm
Help!!
Please ask the developers of this unofficial release of Android for support.
RPi 4B 4GB (SSD Boot)..
Return to “Android”
