dsyleixa123
qtcreator: how to write in a text frame widget by the program? [solved]
Fri Oct 04, 2019 9:19 am
qtcretor/designer:
how to write in a text frame widget by the program? (no extra window/no extra box)
It should be integrated into the main window, just like labels or buttons, and should be able to scroll automatically for either new line, feat. a vertical and a horizontal scroll bar.
dsyleixa123
Re: qtcretor: how to write in a text frame widget by the program?
Fri Oct 04, 2019 12:13 pm
PS,
I can d+d TextEdit or PlainTextEdit to my form, but I have no idea how to
ui->PlainTextEdit->TextColor(black);
ui->PlainTextEdit->Writeln("Hello World");
procount
Re: qtcretor: which is the name of a text frame widget where one can write and writeln text messages by the program?
Fri Oct 04, 2019 1:43 pm
ui->PlainTextEdit->setStyleSheet("{color: black}"); https://doc.qt.io/archives/qt-4.8/style ... mples.html
ui->PlainTextEdit->setPlainText("Hello World"); https://doc.qt.io/archives/qt-4.8/qplai ... mbers.html
dsyleixa123
Fri Oct 04, 2019 2:35 pm
hi,
thanks, I now get 1 single "Hello Word"
But if I do that repeatedly, I do not get many of them, one after the other
Hello WordHello WordHello WordHello WordHello WordHello WordHello WordHello Word
and also not beneath each other liike using writeln("Hello Word"), i.e. seperated by a "\n"
Hello Word
Hello Word
Hello Word
Hello Word
Hello Word
also if I try instead "Hello World\n"
theres only just 1 single
Hello Word
and that's it :roll: :roll: :roll:
dsyleixa123
Fri Oct 04, 2019 3:08 pm
just found out:
ui->PlainTextEdit->appendPlainText
makes line feeds in between
but how to write anything just behind one another?
dsyleixa123
Fri Oct 04, 2019 4:40 pm
weird that there is no simple print/println funcion available, preferably formattable by stdio sprintf parameters, and automatically writing 1 string behind another... :(
Paeryn
Sat Oct 05, 2019 1:53 am
There is insertPlainText() which inserts the text at the current cursor position (if the cursor is a selection then the selection is replaced with the text). The edit box's current cursor can be obtained with
EditBox->textCursor()
Infact insertPlainText() is a convenience function which does
EditBox->insertPlainText(text_to_insert);
// is equivalent to
EditBox->textCursor().insertText(text_to_insert);
TextCursor is of the type QTextCursor and has all the methods for defining where in the edit field the cursor is at.
dsyleixa123
Re: qtcreator: how to write in a text frame widget by the program?
Sat Oct 05, 2019 8:03 am
thank you!
as my EditBox is called "PlainTextEdit", so IIUC: one needs 2 commands to write 1 string after the other
for write in PlainTextEdit (flowing text)
#define Qwrite(str)  { ui->PlainTextEdit->textCursor(); ui->PlainTextEdit->insertPlainText(str); }
for writeln (\n) in PlainTextEdit (wordwrap):
#define Qwriteln(str)   { ui->PlainTextEdit->appendPlainText(str); }
cumbersome - but correct?
Now perhaps sort of an extra gotoxy(x,y) to move the cursor to (x,y) would be nice 8)
Paeryn
Sat Oct 05, 2019 9:09 am
thank you!
You don't need the ui->PlainTextEdit->textCursor(); here, it just returns the QTextCursor but you throw that away (you don't assign it to a variable or use it in any way). PlainTextEdit->insertPlainText() calls the insertText() method of PlainTextEdit's QTextCursor for you.
There are quite a few methods you can call on a QTextCursor to move it to your desired location within the contents of the edit box, see https://doc.qt.io/qt-5/qtextcursor.html
dsyleixa123
Sat Oct 05, 2019 9:21 am
thank you for your explanations!
Also thank you for your link (I actually knew that link already), but those tons of stuff are conpletely overburdening and confusing... :roll:
dsyleixa123
Sun Oct 06, 2019 7:00 pm
IIUC, there are only relative move actions (up, down, left, right,...), no absolute (x,y) for (rownumber, linenumber)
(enum QTextCursor::MoveOperation)
Paeryn
Sun Oct 06, 2019 9:34 pm
You can move to an absolute position within the document with
QTextCursor::setPosition(int pos, QTextCursor::MoveMode m = MoveAnchor)
Setting it to an arbitrary line and column (assuming by line y you mean block y and by column x you mean xth character of block y) then you could always do this to position the cursor at (column x, line y) assuming both line and column are 1-based (i.e. start at 1 rather than 0)
    QTextCursor cursor = ui->plainTextEdit->textCursor();
    cursor.movePosition(QTextCursor::Start);
    if (y > 1)
         cursor.movePosition(QTextCursor::NextBlock, QTextCursor::MoveAnchor, y-1);
    if (x > 1)
        cursor.movePosition(QTextCursor::NextCharacter, QTextCursor::MoveAnchor, x-1);
    ui->plainTextEdit->setTextCursor(cursor); // move the edit's cursor to the new position
    ui->plainTextEdit->insertPlainText("*");
I moved the widget's cursor at the end so that plainTextEdit->insertPlainText() will insert at the selected position.
movePosition() will return false if it fails to make the requested number of movements (like reaching end-of-document).
dsyleixa123
Mon Oct 07, 2019 7:45 am
thank you very much!
It's not urgent for me right now but I'll keep it in mind if I once will need a text spreadsheet, but ftm it's too complicated tbh...
Return to “C/C++”
