sixtips4u
Settings app crashing on Custom Android 7.1
Thu Oct 03, 2019 11:06 am
Im using Android 7.1 on RPI-3B. i.e. the settings app crashes whenever any item in the drawer is clicked. Has anyone found a fix for it. I'm using my custom android build with telephony enabled in tablet mode. Please find a snippet of my logs below:
10-02 11:14:46.631 573 573 D AndroidRuntime: Shutting down VM
10-02 11:14:46.633 573 573 E AndroidRuntime: FATAL EXCEPTION: main
10-02 11:14:46.633 573 573 E AndroidRuntime: Process: com.android.settings, PID: 573
10-02 11:14:46.633 573 573 E AndroidRuntime: java.lang.NullPointerException: Attempt to invoke virtual method 'android.content.pm.UserInfo android.os.UserManager.getUserInfo(int)' on a null object reference
10-02 11:14:46.633 573 573 E AndroidRuntime: at com.android.settingslib.drawer.SettingsDrawerActivity.updateUserHandlesIfNeeded(SettingsDrawerActivity.java:325)
10-02 11:14:46.633 573 573 E AndroidRuntime: at com.android.settingslib.drawer.SettingsDrawerActivity.openTile(SettingsDrawerActivity.java:299)
10-02 11:14:46.633 573 573 E AndroidRuntime: at com.android.settings.dashboard.DashboardAdapter.onClick(DashboardAdapter.java:389)
10-02 11:14:46.633 573 573 E AndroidRuntime: at android.view.View.performClick(View.java:5637)
10-02 11:14:46.633 573 573 E AndroidRuntime: at android.view.View$PerformClick.run(View.java:22429)
10-02 11:14:46.633 573 573 E AndroidRuntime: at android.os.Handler.handleCallback(Handler.java:751)
10-02 11:14:46.633 573 573 E AndroidRuntime: at android.os.Handler.dispatchMessage(Handler.java:95)
10-02 11:14:46.633 573 573 E AndroidRuntime: at android.os.Looper.loop(Looper.java:154)
10-02 11:14:46.633 573 573 E AndroidRuntime: at android.app.ActivityThread.main(ActivityThread.java:6121)
10-02 11:14:46.633 573 573 E AndroidRuntime: at java.lang.reflect.Method.invoke(Native Method)
10-02 11:14:46.633 573 573 E AndroidRuntime: at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:889)
10-02 11:14:46.633 573 573 E AndroidRuntime: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:779)
10-02 11:14:46.638 417 907 W ActivityManager: Force finishing activity com.android.settings/.Settings
Re: Settings app crashing on Custom Android 7.1
Thu Oct 03, 2019 12:16 pm
Have you asked the developer of this unofficial port of Android for help ??
RPi 4B 4GB (SSD Boot)..
salehdeh76
Tue Feb 18, 2020 5:17 pm
Did you find the problem? I am facing same issue!
Tue Feb 18, 2020 7:50 pm
Probably best to start afresh with a Konsta Build, as the Original Poster never stated what build of Android they used and therefore how could you know it is the same issue ??
viewtopic.php?f=73&t=243832
viewtopic.php?f=73&t=261228
Return to “Android”
