bertlea
New Raspbian Buster image (Sep. 2019)
Wed Oct 02, 2019 8:52 am
I see a newer version of Raspbian Buster is available for download. Am I correct that, I can just do the "sudo apt-get update; sudo apt-get upgrade" on my existing Raspbian Buster and that can make system reach the same level of updateness, including the latest SPI EEPROM after a reboot?
i.e. the newer image is only for people want to install a fresh new copy of the Raspbian Buster from a more up-to-date starting point right?
B.Goode
Re: New Raspbian Buster image (Sep. 2019)
Wed Oct 02, 2019 9:28 am
No.
Wed Oct 02, 2019 9:34 am
sudo apt update; sudo apt dist-upgrade -y; sudo reboot should get you to a similar level as the 2019-09-26 Raspbian but you may miss out on new packages that weren't in the original Buster delivery.
This is a doctor free zone.
bertlea
Wed Oct 02, 2019 9:45 am
Thank you both for the feedbacks. I will install the new image and start from scratch then.
ShiftPlusOne
Wed Oct 02, 2019 10:06 am
The kernel in that image has been removed from the repo for now. There's a new 64 bit kernel file and some people have partitions that it won't fit on, so I need to add a check that will block the upgrade in those cases. Just to prevent bricked pis.
thatchunkylad198966
Wed Oct 02, 2019 5:06 pm
Hi...
This is the only post I found with info on the new .ISO -- where can I find a change list? like what's been fixed?
One man's trash is another man's treasure! :) Pi's I have; Pi Zero, Pi Zero W, Pi 2 x2, Pi 3 x2, Pi 4 4GB x2.
DirkS
Wed Oct 02, 2019 5:41 pm
Hi...
There's a link to the release notes on the download page (several links, actually)
geev03
Wed Oct 02, 2019 5:43 pm
[email protected]:~ $ uname -a
Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
fbe
Wed Oct 02, 2019 5:49 pm
Hi...
I guess the main "fix" is the upgrade from Debian Stretch to Debian Buster... (for PC and Mac) With Raspberry Pi Desktop. But I agree, a release notes link wouldn't hurt on the download page.
DirkS
Wed Oct 02, 2019 6:04 pm
Hi...
No, the upgrade from Stretch was in the previous image (June). This topic is *not* about Pi desktop for PC/Mac.
See my post above re release notes...
thatchunkylad198966
Wed Oct 02, 2019 6:11 pm
Hi...
I'm not posting about x86/64; I'm on about for Raspberry Pi's -- not desktop.
Thanks, though.
I'll have to search for the release notes! :D
MrEngman
Wed Oct 02, 2019 6:21 pm
Hi...
Thanks, though.
There are links to the release notes on the Raspbian download page https://www.raspberrypi.org/downloads/raspbian/
MrEngman
fbe
Wed Oct 02, 2019 6:26 pm
Thanks, though.
MrEngman
Sorry, my misunderstanding came from "ISO". There is no ISO with Raspbian whereas the release notes for Raspbian are quite easy to find...
HermannSW
Wed Oct 02, 2019 6:41 pm
I did that, and quite some packages were installed.
But there was neither difference in /etc/osrelease nor in "uname -a" after reboot.
I am after new "-dn" option of raspivid, and that was not available either.
So I did "sudo rpi-update" and rebooted.
Only "uname -a" is different now:
[email protected]:~ $ diff <(cat /etc/os-release && uname -a) o.txt
11c11
< Linux raspberrypi4B 4.19.75-v7l+ #1271 SMP Mon Sep 30 13:51:15 BST 2019 armv7l GNU/Linux
> Linux raspberrypi4B 4.19.66-v7l+ #1253 SMP Thu Aug 15 12:02:08 BST 2019 armv7l GNU/Linux
But I got new "-dn" option, will test that when back home on weekend:
[email protected]:~ $ raspivid | grep dn
-dn, --dispnum	: Display on which to display the preview window (dispmanx/tvservice numbering)
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
bertlea
Thu Oct 03, 2019 2:18 am
Edit: I did not understand it correctly, please ignore my message earlier below.
@HermannSW, I guess your observation is related to ShiftPlusOne's message:
klricks
Thu Oct 03, 2019 2:49 am
ShiftPlusOne's message is related to this thread: https://www.raspberrypi.org/forums/view ... 6&t=253259
wally333
Sat Oct 05, 2019 11:13 am
What exactly may we be missing out on that wasn't in the original Buster delivery?
Couldn't they simply be added if needed with sudo apt-get install pkg.name??
To re-iterate, is this the recommended way to upgrade the original Buster image?
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update
Since It took an absurd amount of time to build OpenCV on Buster, starting over is not happening anytime soon.
The status of rpi-update is fuzzy for me right now, as in this thread I see it recommended as "needed" but in others its "obsolete" and should not be used.
Inquiring minds what to know.
Sat Oct 05, 2019 11:20 am
sudo apt-get update
sudo rpi-update
Nobody knows, unless there's a list of new and changed packages (about which I care not a jot).
rpi-update NOTICE.md wrote:HASH: 152b6b858d2f6b94fa398fa4545d5e130ab24434
WARNING: 'rpi-update' updates to pre-releases of the linux
kernel tree and Videocore firmware.
'rpi-update' should only be used if there is a specific
reason to do so - for example, a request by a Raspberry Pi
engineer.
DO NOT use 'rpi-update' as part of a regular update process.
Do NOT EVER run rpi-update unless an expert tells you to run it.
wally333
Sun Oct 06, 2019 3:54 pm
Thanks for the definitive answer.
I appreciate it.
bensimmo
Sun Oct 06, 2019 5:16 pm
If the rpi-eeprom program hasn't come down with a full-upgrade, you'll need to apt install it
wally333
Mon Oct 07, 2019 4:29 pm
What is the purpose of rpi-eeprom? Why would I need it?
bensimmo
Mon Oct 07, 2019 4:46 pm
It updates (or allows you to update if you set it to manual) the bootcode.
https://www.raspberrypi.org/documentati ... teeprom.md
And its changelog
(Unsure which version we're on, I thought we had the Sdram tweaks, but it still says beta in the changelog.)
https://github.com/raspberrypi/rpi-eepr ... e-notes.md
Return to “Raspbian”
