apt-get update
apt-get dist-upgrade Code: Select all
ssh -f -X -l pi 10.1.1.91 "midori &" Code: Select all
ForwardX11Timeout 0
ServerAliveInterval 15I came across this in /var/log/messages
Sep 30 15:39:47 buzz kernel: [ 14.632305] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
Sep 30 15:39:47 buzz kernel: [ 15.353613] sd 1:0:0:0: [sdb] Very big device. Trying to use READ CAPACITY(16).
Sep 30 15:39:47 buzz kernel: [ 15.867742] EXT4-fs (sda2): recovery complete
Sep 30 15:39:47 buzz kernel: [ 16.409011] EXT4-fs (sdb1): recovery complete
Sep 30 15:43:51 buzz kernel: [ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
Sep 30 15:43:51 buzz kernel: [ 0.926480] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Sep 30 15:43:51 buzz kernel: [ 0.926490] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Sep 30 15:43:51 buzz kernel: [ 1.633309] EXT4-fs (mmcblk0p2): recovery complete
The disks in question are these
/dev/sda2 4.6T 2.6T 1.8T 60% /mnt/extend
/dev/sdb1 4.6T 2.6T 1.8T 59% /mnt/downloads
TIA
